BPFox wrote:Read his post again. It's a 70 amp panel not a 70 amp breaker. He can use a 200 amp panel if he want's to. His original question was "what size breaker should I use?" Let me see here. He is going to plug his 20 amp rated extension cord into a 20 amp power panel and he is wiring his single circuit two receptacle system. The answer to his question is 20 amp breaker. Why is he using a 70 amp panel? Because he could not find a 30 amp panel. The size of the panel only indicates the maximum for the panel. It has nothing to do with the breakers or the wiring.
my point and my only point...thank you very much................................
