Just something to think about before you install the trim..
Micro469 wrote:... When I went camping at ADK, Steve F. saw it and muttered something about surface tension on the edges of the trim, and how the epoxy would pull away from the edges, so that however number of coats you give it, it would still be very thin. I now find moisture is getting under the edge, and causing the epoxy to lift....Just something to think about before you install the trim..
WarPony wrote:Micro469 wrote:... When I went camping at ADK, Steve F. saw it and muttered something about surface tension on the edges of the trim, and how the epoxy would pull away from the edges, so that however number of coats you give it, it would still be very thin. I now find moisture is getting under the edge, and causing the epoxy to lift....Just something to think about before you install the trim..
Wow, I was under the impression that epoxy was the ONLY way to go because of the durability it has. I had no idea sharp edges would cause a problem like you have.
John, what brand of epoxy did you use? I'm glad I ran into this thread before I bought any epoxy or 'glass product.
Jeff
tonyj wrote:You should also consider the fact that epoxy has nothing in the area of UV inhibitors and will break down over time with sun exposure. The only way to prevent this is to cover it with varnish that has UV protection (like schooner varnish) or possibly automotive clearcoat. I am sure about the varnish, less sure about the auto clearcoat.
WarPony wrote:UNHIJACK!!!!
Dave, that hatch looks great...... hell, the whole build is a work of art!!!!! Thanks for posting the pictures, it's been a great inspiration for me to build woodies.
Jeff
Micro469 wrote:When I went camping at ADK, Steve F. saw it and muttered something about surface tension on the edges of the trim, and how the epoxy would pull away from the edges, so that however number of coats you give it, it would still be very thin.
Juneaudave wrote:John...I've never really seen anything like that except on boat gunnels where tie down straps or something rubs over time.
Is it possible that there is a compatibilty issue going on? It sort of looks to me like either there is a stain/epoxy issue like the epoxy didn't penetrate in...or maybe...did you wipe down with a solvent of some sort prior to applying epoxy? It can sure be fixed but it would be real nice to figure out whats up. I know for a fact that the MAS epoxy I use doesn't adhere well with the oils in the purple heart unless wipe down with acetone first...that's why I ask....Juneaudave
