thanks
BPFox wrote:I think it might work if installed properly. I wouldn't use 2x4 studs, I would go with 1 5/8 studs. 1 inch foam fits inside the stud and it makes for a pretty clean set up. It's how I did my basement walls. Didn't want to attach anything to the outside walls and I didn't want to give up too much space. The 1 5/8 studs work pretty good for this. In a trailer application using a plywood skin it would be pretty solid. The weight wouldn't be that much more and they would make for a much faster build. Curving the track might be a bit of a pain, but it could be done.
COMP wrote:BPFox wrote:I think it might work if installed properly. I wouldn't use 2x4 studs, I would go with 1 5/8 studs. 1 inch foam fits inside the stud and it makes for a pretty clean set up. It's how I did my basement walls. Didn't want to attach anything to the outside walls and I didn't want to give up too much space. The 1 5/8 studs work pretty good for this. In a trailer application using a plywood skin it would be pretty solid. The weight wouldn't be that much more and they would make for a much faster build. Curving the track might be a bit of a pain, but it could be done.
i haven't see the 1 5/8" ones ,,,,H D have them ??
