What I can use to waterproof that wooden AC tray?
Postby mikeschn » Sat Jul 12, 2008 4:40 pm
I'm looking for a good suggestion. I have my air conditioner sitting in a wooden tray, but I don't want the wood to get wet and rot out.
It's currently covered by a couple layers of spar urethane, but I don't think that's enough.
Any suggestions what I can use to waterproof that wooden tray?
Postby Galen » Sat Jul 12, 2008 4:44 pm
My normal response to any wood needing water proofing is epoxy. Maybe a layer of 4 oz. fiberglass also for abrasion. But since you already have urethane on it, I don't think that will work.
Galen
Postby toypusher » Sat Jul 12, 2008 6:34 pm
Not sure on this, but what about the stuff that you dip tool handles in to put a rubberized grip on them?? It is liquid and you could probably just poor it around in there and paint it up the sides a bit.
something like this: http://www.kk.org/cooltools/archives/000210.php
Here's another place: http://www.gemplers.com/list.aspx?SKW=t ... |974963785
toypusher
Images: 324
Postby mikeschn » Sat Jul 12, 2008 6:47 pm
I like the looks of that clear coating from Gemplers, but I am not going to pay $107 for a gallon of the stuff!!! :o :o :o
Any other ideas?
Postby tinksdad » Sat Jul 12, 2008 7:54 pm
WOW!!!! Not to go off topic...... but when one of the "masters" asks for opinions; I don't feel so DUMB anymore!!! :?
tinksdad
Images: 155
Postby rainjer » Sat Jul 12, 2008 8:09 pm
What about making a metal tray out of some galvinized sheet with a 1" lip around the edge. You could use roofing caulk to seal the corners.
Jeremy
rainjer
King Koleman
Images: 11
Postby Steve_Cox » Sat Jul 12, 2008 8:20 pm
I made my wooden A/C tray waterproof with epoxy. But you probably knew that cause I love that stuff :lol:
Steve_Cox
Images: 196
Postby madjack » Sat Jul 12, 2008 8:42 pm
...why a rubber mat and a SHAMWOW :D :lol: :lol: :lol: ;) ............................... 8)
Postby BrwBier » Sat Jul 12, 2008 9:25 pm
We got a clear water proofing brush on product at Menards. We used it around skylights on the roof and 5 years latter it is still clear and no leaks.
Brwbier
BrwBier
Images: 100
Postby Jiminsav » Sat Jul 12, 2008 11:15 pm
madjack wrote:...why a rubber mat and a SHAMWOW :D :lol: :lol: :lol: ;) ............................... 8)
Thats right MadJack...and a Shamwow would suck the water out of the air before it even hits the A/C.. :lol: :lol: :lol:
Jim in Savannah
Jiminsav
Images: 40
Postby Tear Fan » Sun Jul 13, 2008 6:08 am
What about the stuff they use on bartops. It looks like it's about an inch thick - but it's not. That oughta do it for ya'.
Life is so short, we should all move more slowly. - Thich Nhat Hanh
Photos - http://flickr.com/photos/47726343@N00/
Tear Fan
Images: 70
Postby Miriam C. » Sun Jul 13, 2008 9:55 am
PVC shower base stuff will do it and you don't have to stick it down. Just cut and cement the corners.
Mine is done with epoxy. An after thought and the epoxy stuck to the polyurethane. :roll: At least I think it did.
Postby Mstro » Sun Jul 13, 2008 10:45 am
I see by some of the post fiber glassing the area leaves a clear finish and is water tight, but requires a lot of work and special venting considerations during the application. :thinking:
If you can get by with a rubber membrane for a pan, one is available from HD or lowes that is used under shower stall installations. its available by the foot.
Personally I'd prefer the clear approach :thumbsup:
Marc
"Those who dream by day are cognizant of many things which escape those who dream by night."
Mstro
Images: 29
Postby asianflava » Sun Jul 13, 2008 7:26 pm
I used epoxy and glass cloth, I don't remember what the weight was. It was to glass the fins on one of my rockets so it was pretty light weight cloth.
asianflava
Postby mikeschn » Sun Jul 13, 2008 7:30 pm
I guess the question is, can you epoxy over spar urethane?
