Ready now for step two.
McTeardrops wrote:Jeff
I used an HF air shear to make the cuts. (Actually two, since the first died during the last cut.) The .060 aluminum cut like butter, except when it wouldn't cut at all, but as this was the first time the shear was out of the box, I still don't know if the problem was tool, material, technique or operator. I climbed right up on the table for the long cuts, so reach wasn't much of a problem. As you indicated, the most nervous-making cut was splitting 48+" and 54"+ widths out of 103" stock!
