Hey Del....spend a couple of hours here...I'm sure you'll come up with something... http://www.allmanufacturedhomes.com/htm ... _homes.htm
Have fun! Doug
I edited your post for you.doug hodder wrote:Hey Del....spend a couple of days here...I'm sure you'll come up with something... http://www.allmanufacturedhomes.com/htm ... _homes.htm
Have fun! Doug
yepSamR wrote:Good Grief Del, Do you lay awake at night thinking of the projects that'll cause the most headaches and then pick out the worst to start?
Oh great another book to drool overdoug hodder wrote:Del...another resource to check out is "Trailer Travel, a visual history of mobile America" the book. Tons of great pics there from trailer sales shows back in the 30's. I just got the idea for the trolley tops from what Craigs nephew had done and books etc...that I've seen. Nothing in particular. Doug
Thanks Johnny. No not a trailer grave yard, just my friends 30 acres, and yes there is a lot of interesting stuff there.Ivar the Red wrote:Looking good Del. Here's what I finally decided on for the rust...
http://www.ospho.com/
It works good and is easily avaible, I got mine from Ace Hardware. I also went with a primer coat after the stuff dried. Overkill??? it made it easier to tell where I was at when painting black onto black.
Anyways, I liked the Ospho because it is a liquid, and while the rattle can stuff I found at Wally World worked well and made it's own primer, it just seemed to me that a lot of it floated away in the form of overspray.
Is that a "trailer grave yard" you're working in? I found a place like that on the way back from Palo Duro Canyon, but haven been back to check it out yet...maybe when I get closer to needing windows and such.
I am thinking the straitening the frame and moving the axle back will be the better option, let me pass this by my welder friend. The large step outside the trailer scares me (and my handicap), so moving it inside helps.angib wrote:Hmmmm...... not that easy.
As you might have been encouraging me to do, having given all those dimensions, here is a quick sketch of what I think your frame looks like. Here I've positioned it so the axle is in the (guessed) right place - more work is needed to see if that really is the right place:
I am guessing the axle is unmoved and the tongue is lengthened "X" amount of inches
It's too long at the back and way too short at the front, but by similar amounts - so here it is with the frame slid 15" forwards, but leaving the axle where it was:
That's a reasonable fit, though the rear axle bracket is now well behind the kink in the left frame rail (leaf spring coloured red) - I think the only choice there is to cut the frame rail at the kink and build it back in straight. This is a fair amount of work, because that means re-making the joints further back too. I can make this strait and move the axle, I am assuming this way requires no tongue extension
So that just about works.
Now comes the dropped floor question. This produces several glitches that need more thought:
- having a leaf spring pushes the back end of the dropped floor forwards by 9" or so (not ideal, but bearable);
- at the joints in the frame rail, the rails need to overlap by 9" or so, but there is no spare rail length available;
- ditto at the A-frame (where it 'un-drops' back to a normal frame height) with the added problem that the A-frame couldn't be overlapped even if there was enough material, because the A-frame has a fixed width.
It might be possible to add new material in at the drops, but that will make the joints longer and so it will make the dropped floor shorter. What are the frame rails and A-frame made of (depth, width, thickness)? Joining that C-channel isn't going to be that easy, whichever way it's done.
It might be worth thinking about only having the dropped floor between the frame rails, like on this replacement chassis for a Boler fiberglass trailer:I do believe we have a winner
Note that in these trailers, there is some fancy work to kink one frame rail below floor level for the length of the door opening, so it's not necessary to step over the frame rail to reach the dropped floor.
Andrew
