MY TENT TRAILER DEMO PICS....UPDATED July 14
Postby Miriam C. » Fri Jun 22, 2007 7:00 pm
:o Odd, that looks like someone tried to make a repair or cut away the frame to loose some weight.
Looks sturdy enough to do the job. :thumbsup:
Postby Ken A Hood » Fri Jun 22, 2007 7:34 pm
And it was 5/8" plywood decking....and I haven't found any soft spots yet and when I was walking on it it felt sturdy enough.
Disclaimer: I in no way resemble the avatar shown. Furthermore, I in no way have any affiliation to the Trailer Park Boys and more specifically Bubbles!
Ken A Hood
Images: 42
Postby sledge » Fri Jun 22, 2007 8:24 pm
Now your talkin', Your ready to get started now on the Good Stuff. :applause: :applause: :applause:
sledge
Images: 26
Another Popup conversion
Postby daveleb55 » Tue Jul 31, 2007 7:30 pm
Hey, Ken;
I just got an old Coleman for $250, it looks to be in pretty good shape. I'm keeping the two sidewalls and the floor, but the rest is going. I'm recycling the stove/sink/ cooktop, and probably the tail lights and whatnot.
I'm interested to see if you've made any progress on yours since your last post.
Dave
Ken A Hood wrote:And it was 5/8" plywood decking....and I haven't found any soft spots yet and when I was walking on it it felt sturdy enough.
"Get off the #@$% computer and GO CAMPING!"
daveleb55
Images: 203
Postby Ken A Hood » Mon Jul 14, 2008 3:08 pm
Finally got around to ripping the rest of the deck off. Solid except for a small spot near the door. There a pic in the link showing a piece of the deck....it's got black stuff on the underside, held up well for a 30 + years it's been in the weather.
Odd framing, the outer "rails" is a solid 2"x2" on one side (where the door was) , the other side (and past the fenders) has just a little piece/stub. The 2 inside main rails are 2"x4", while the A frame is 2"x3", while the other cross members are 1 1/2" angle iron.
Also in a couple of the pics is one of my 1/2 axles (thinking about replacing the current axle [with 13" tires on 4-4" bolt pattern] with the 5- 4 1/2" bolt pattern with 15" tires raising the overall stance of the trailer (approx. 4-6" which will look better behind my tow vehicle 4x4 F-350)
I'm going to draw out the frame in AutoCad; took the measurements today while also grinding off all the torx deck screws (100+ and counting)
In pic 7 it shows how the A frame was welded, I'm probably going to remove that 1st 1 1/2 " angle member and replace it with a 2"x2" close to teh bracket (for added support/strength) and might add a dropped footwell since there's room for it.
http://gs254.photobucket.com/groups/hh117/4VPV105R82/
Ken A Hood
Images: 42
Postby Hector » Mon Jul 14, 2008 3:15 pm
Hey Ken I tried but the link did not work.
Hector
Images: 46
Postby Miriam C. » Mon Jul 14, 2008 5:10 pm
:o Ken it is not public and wants a password. :thumbsup:
Postby Ken A Hood » Mon Jul 14, 2008 5:48 pm
I think I changed it to public now.....
Ken A Hood
Images: 42
Postby Miriam C. » Mon Jul 14, 2008 5:53 pm
:thumbsup: That did it. Looks good with the new axles. :thinking: The doubling of the rails must be to hold heavy stuff on that side or something.
:twisted: Now you just need some sawdust. :twisted:
Postby Ken A Hood » Mon Jul 14, 2008 6:27 pm
Here's the rough AutoCad drawing; I'll be adding the dimensions later
Ken A Hood
Images: 42
