tonyj wrote:Not an uncommon problem.
One thing I have seen many builders do is run rain channel down the side in front of the door. Mine runs about half way down, but I also have an inner seal to prevent water from entering that gets past. You would probably have to run a channel that is a little longer than your door is tall.
tonyj wrote:For the duct tape method, outside is the best. Just for travelling, of course.
Here is a pic of my inside door frame and seal:
tonyj wrote:Here is a pic of my inside door frame and seal:
tonyj wrote:Back to your original post, I think they make 1/8 foam that shouldn't spring your hinge as much, or Miriam's suggestion.
TPMcGinty wrote:Thanks for the help on the 1/8 inch foam weather stripping. I found it at home depot. I thought it would work but the doors still won't close with even as little as 1/8 inch in the hinges. I don't know what to do.
