bobhenry wrote:I was following a couple good old boys with 5 38" - 42" in in diameter logs about 20' long on a tandem axle trailer. Halfway down a 35 degree grade was a road to the right. The good old boys wanted to turn and did
( more or less) The trailer picked the truck up by the ball and deposited the driver side rear tire dead center in the middle of the hood of a pristene thunderbird with a very hysterical woman screaming at the top of her lungs. Boys that's 3 1/2 ' into the air. They will lift under braking I saw it !!
G-force wrote:brian_bp wrote:G-force wrote:Under braking, especialy trailers with no brakes, all the trailers deacceleration is done by the tow vehicle. As you brake, the trailer is is being pushed into the tow vehicle. If its level, it will push in level. If the trailer is nose high, it will start taking weight off the rear wheels as it raises the coupler assembly. In a panic stop, you can get in the situation where enough weight is lifted off the rear wheels of the tow vehicle and the whole thing jackknifes. Having the trailer level, or slightly downward prevents this...
This doesn't make any sense to me. The effect which is described here is real, but depends only on the ball height - whether the frame of the trailer is level or not is irrelevant.
By this standard, all towing balls should be as low as possible (and there's something to be said for that), regardless of trailer attitude.
Actualy, it depends on the center of gravity of the trailer in relation to the axle (pivot point) and the coupler. Most trailers the CG (up and down, the vertical plane) is above the ball so it indeed usualy pushes down on the bumper of the tow vehicle. But some trailers, usualy utility trailers or boats, with a heavy load close to the pivot point, can get the ball above the CG. I agree, an inch or two probably doesnt matter for 99% of the vehicles and trailer out there. But a lifted 4x4 truck with the ball on the bumper towing a 5x8 utility trailer with a ton and a half of gravel with the nose of the trailer pointed way up is asking for trouble. Remember, we are striving for the safest geometry possable, given the choice of having an ideal situation, or something the "probably is ok", I'll take the former.
Mike
PS: I'm not sure CG is the proper term for what I am trying to say, I mean the center of the mass of the trailer as its mass is deacellerated...I'm sure an engineer can correct my terminology.
bobhenry wrote:I was following a couple good old boys with 5 38" - 42" in in diameter logs about 20' long on a tandem axle trailer. Halfway down a 35 degree grade was a road to the right. The good old boys wanted to turn and did ( more or less) The trailer picked the truck up by the ball...
brian_bp wrote:G-force wrote:brian_bp wrote:G-force wrote:Under braking, especialy trailers with no brakes, all the trailers deacceleration is done by the tow vehicle. As you brake, the trailer is is being pushed into the tow vehicle. If its level, it will push in level. If the trailer is nose high, it will start taking weight off the rear wheels as it raises the coupler assembly. In a panic stop, you can get in the situation where enough weight is lifted off the rear wheels of the tow vehicle and the whole thing jackknifes. Having the trailer level, or slightly downward prevents this...
Mike
Center of Mass is the ideal term, but C of G is effectively the same thing... the meaning is clear.
Yes, the C of M height is relevant too (sorry, I should have acknowledged that), but moving the tongue up and down doesn't change that height in any material way... a trailer tilted nose-up doesn't have a lower C of M than the same trailer tilted nose-down, so the angle of tilt doesn't matter, only the height of the ball. Again, low is good for towballs, at least as far as reducing effect on the tow vehicle is concerned.
If the trailer mass is significant compared to the tow vehicle (such as a ton or more of trailer pulled by a two-ton vehicle), then the trailer should be doing most of its own braking - most of the force should not be through the ball. Braking force applied by the trailer tires will require a corresponding transfer of load from the trailer axle to the tongue (that is, braking the trailer puts more load down on the hitch), so it's hard for me to see a braking control problem related to ball height.
G-force wrote:Your right, the actual angle of the trailer is not an important factor, all that is important is how high above the axle centerline (the pivot point) the center of mass is in relationship to the ball. The frame inbetween can be any shape, bend, angle, etc. Since most trailer frames are built flat, and designed to be towed level, I was genericly using the term "angled up" and "angled down" to indicate an attitude taller or shorter than designed. Lets say you could pick a trailer up and stand it on a balance beam on it front face, and discover where the center of the mass was. Lets say it is 20 inches above the axle centerline. Under braking, assuming the trailer has no brakes, if the ball is right at 20 inches above the trailers axle, all the forward push into the trailer will be in a straight, level vector. If the ball is above that 20 inch point, it will lift the ball as it tries to overrun the tow vehicle. Anytime the ball is below that 20 inch level, the momentum will push the ball downward. Agree?
G-force wrote:As for trailer brakes, most utility and small tear trailers dont have them. Here in California, you dont need brakes untill you are over 3500 lbs. I agree the forces on a trailer and tow vehicle are very different when dealing with a trailer with brakes.
brian_bp wrote:BPFox, your tilting trailer design is very much like some industrial equipment trailers which I've seen on the road here in Alberta. They are pulled as semi-trailers (fifth-wheel at the front, axle at the very back), and are basically a rectangular box which looks like it sits directly on the ground at the job site, and is tilted nose-up significantly to tow. Yes, the fifth-wheel plate is level when towing, and at a significant angle to the box of the body. I suspect that they use air suspension on the trailer axle, but that's only a guess.
Sorry, no photo available.
Jason and Amanda wrote:I'm surprised that nobody has asked the OP (original poster) what his tow vehicle is and how much his trailer weighs.... this no doubt has the greatest impact on towing regardless of the other factors.
Jason and Amanda wrote:The OP is pulling with a minivan, so it's still front wheel drive but weights a bit more therefore has a bit better braking and stability. I'm sure the towing capacity is probably 1500 lbs (or thereabouts)...
