Removing fenders from Northern Tool 5x8 trailer(?)
Postby madjack » Tue Jul 22, 2008 9:05 am
David, it sound as if your have most of the basics covered...keep the guard in place, make sure everything is tight...if you use a cutting disk, dont try to grind with it and keep it straight into the cut...if you are getting the metal "redhot" you are working way too hard :lol: ...oh yeah, whatchout for where the sparks are going, you can set yourself or something else on fire :D ;) ...........
madjack 8)
Postby SmokeyBob » Tue Jul 22, 2008 9:16 am
madjack wrote: ...oh yeah, whatchout for where the sparks are going, you can set yourself or something else on fire :D ;) ...........
madjack 8)
Gives a new meaning to You light up my life :)
Pics for Building the Alegria I
To view video click Here
Bob & Judith
SmokeyBob
Images: 161
Postby angib » Tue Jul 22, 2008 4:56 pm
madjack wrote:...oh yeah, whatchout for where the sparks are going, you can set yourself or something else on fire
And if you don't set things on fire, you can embed those nice little hot bits of dust in soft or meltable things, like any plastics nearby. Outside is best.
Andrew
angib
5000 Club
5000 Club
Images: 231
Tonight I used an Angle Grinder for the 1st Time
Postby Alfred » Wed Jul 30, 2008 10:38 pm
Hey Gang,
Tonight I used my new Harbor Freight Angle Grinder for the first time, to remove those ugly factory fenders from my Northern Tool trailer. Last count, I still have 10 fingers and 10 toes, and managed not to burn the place down. It was pretty fun!
Al in Asheville :thumbsup:
Alfred
Images: 368
Postby starleen2 » Wed Jul 30, 2008 10:42 pm
No if you had an Axe then.......... grind away! nothing feels better than to sucessfully remover unwanted fenders
starleen2
5th Teardrop Club
Postby Muggnz » Thu Jul 31, 2008 2:57 am
Jack,
hard work is fun & stress relieving from a hard day @ the office. I use cheap grinding disks. Individually they don't last as long, but the "grind for my buck" is much better.
I agree that each type of disk has it's specified used. However I can cut with grinding discs, without ruining them. It's very hard work to do anything other score a mark in the metal. Whilst grinding using a cutting disk ruins the edge & sometimes the whole blade.
For some reason I've not ( *touchwood* ) been able to set anything alight with grinding sparks. Welding sparks YES. But with grinding I'm still looking forward to the day when it happens, albeit it at someone else's place.
david
Muggnz
Crybaby
Images: 34
Postby Arne » Thu Jul 31, 2008 7:31 am
I'm late to this party, but given the tools I own this is what I would do:
First, drill a couple of holes so I could get my sawzall blade in and cut the fender off as close to the frame as I could.
Then I'd take my 20 dollar 4" angle grinder and grind off what was left.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
