EPDM Roof with Living Hinge
Postby mechmagcn » Sat Jul 19, 2008 8:19 pm
After reading this thread, I too am using the EPDM membrane for my roof and think I'll try the living hinge. We'll see how it works with a steel frame too. I also think I'll put the hinge on and place the EPDM on top of it, don't see where it can hurt.
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby Walt M » Tue Jul 22, 2008 12:35 pm
Here's the first photo of my galley hinge ImageI can't seem to be able to post more than one photo at a time but there in my gallery.
All that is needed for evil to flourish, is for good men to do nothing.
Walt M
Images: 50
Postby madjack » Tue Jul 22, 2008 1:34 pm
Walt, I am curious as to why you didn't lay the hinge flat...that way you could have completely hidden it under the EDPM........
madjack 8)
p.s. the easiest way, to do multiple pics, is to open a second, window or tab with the album, in the second window(or tab).....MJ
Postby Walt M » Tue Jul 22, 2008 2:42 pm
My thought is that there will be two layers of 1/8" ply. on the roof that will come up against the edge of the hinge. Then there will be one more layer of 1/8"ply on the galley that will come to the edge of the hinge so when I cover it all with epdm i'll only have to go over 1 1/4" part of the hinge. did you see how I fastened the hinge to the hatch,in my other pic in my gallery?Image
Walt M
Images: 50
Postby madjack » Wed Jul 23, 2008 12:18 am
...solong as ya gotta plan...they are just great...when they come together :thumbsup: ;)...................... 8)
Postby looped » Wed Jul 23, 2008 12:18 am
i thought the black hinges were the outdoor ones? does that one have the uv etc protections in it?
"face it man. It's just not possible to fry an egg with a bicycle powered hairdryer!"
- Dave Lister
looped
Images: 31
Postby madjack » Wed Jul 23, 2008 12:32 am
I believe it comes in black, white and possibly grey................ 8)
Postby mechmagcn » Wed Jul 23, 2008 6:22 am
madjack wrote:I believe it comes in black, white and possibly grey................ 8)
Yep, three colors to choose from. I got mine in yesterday from Mcmaster-carr, when I opened the box, I thought I must be the biggest fool there ever was. How is this little strip of plastic going to hold a hatch. But when I come on here and see that it is what is being used, I feel a little better now. Now if I just had a hatch to attach it to..... :oops:
Jeff & Micki
53 F100
mechmagcn
Images: 56
Postby Walt M » Wed Jul 23, 2008 7:12 am
Here's what I did.I predrilled the hinge with a counter sink bit, I think this helps with reducing the pucker. the door hinges I did free hand with a drill, the hatch I used my drill press. To attach the hinge to the walls I used s.s. flat head 8x1"screws, to attach the hinge to the door although I still predrilled there's no need to counter-sink this side of the hinge, I used s.s. finish washers with s.s. oval head 8x1" screws Image
Image if you look close you can see some of the screws are a bit out of line here and there.(hence why I chose to do the hatch with the drill press. I hope this helps.
Walt M
Images: 50
Postby madjack » Wed Jul 23, 2008 2:12 pm
Jeff, as long as you got the "harsh environment" hinge from McMaster or the "living" hinge from Monroe, you have the right stuff...
madjack 8)
Postby mechmagcn » Wed Jul 23, 2008 8:16 pm
madjack 8)
Yep, that's the one that I got. Now to build a hatch to attach it to :roll:
Jeff & Micki
53 F100
mechmagcn
Images: 56
Postby Walt M » Wed Jul 23, 2008 8:32 pm
Jeff, be careful about attaching the hinge to the hatch. whether you call it a spur or rail but the first cross member that butts up against the roof spur. they are both cut at an angle. It does not leave much to attach the hinge to, I used #8x3/4" . the 1" I started with poked out through. Walt
Walt M
Images: 50
Postby Walt M » Mon Jul 28, 2008 7:50 pm
If your interested. it all seems to be working well. roof skins come up against the hinge i'll be skining the second layer of ply. on the hatch. After some trimming I'll be adhering the epdm to the whole thing without
any cuts or laps, just one solid sheet. I'll post to let you know the results.
Walt
Walt M
Images: 50
Postby mechmagcn » Mon Jul 28, 2008 9:04 pm
Walt M wrote:Jeff, be careful about attaching the hinge to the hatch. whether you call it a spur or rail but the first cross member that butts up against the roof spur. they are both cut at an angle. It does not leave much to attach the hinge to, I used #8x3/4" . the 1" I started with poked out through. Walt
Walt, no problem there, both my trailer frame and the hatch are framed out of 1" square steel tubing. I also intend to lay my hinge flat on top of the hatch and roof.
Jeff & Micki
53 F100
mechmagcn
Images: 56
Postby Walt M » Wed Aug 20, 2008 6:43 pm
Ok folks it's been awhile. I glued the epdm down right over the living hinge. It does seem to be loose where I went over the hinge, the glue doesn't adhear to the hinge. but it works well I milled some Azek trim (white) for my Tear. The trim I milled for the outside corner bent like a charm, they tell me it can bend to a tight radius if you heat it with a roof torch. I didn't need to, Here are some photos , there are more in my gallery . One more weekend and I should be finished with my first build. I'll be taking it to a gathering in Oct. in Ma. Steve's manual sure made it easy to move along (I made some small changes) Thanks to all you who participate on this forum. BTW When do I stop being a Newbie. Blessings All Walt Image
Walt M
Images: 50
