Trouble installing interior roof
Postby rtp123 » Wed Jul 23, 2008 1:29 pm
Hi all: I am having trouble installing the interior roof. It is 1/8 inch birch MDF plywood. Is there a trick to getting it to bend and stay in place long enough to attach it to the roof spars? :?
Thanks for any help on this one..
rtp123
Postby alffink » Wed Jul 23, 2008 2:17 pm
rpt123
Do you have a real name that I can answer to??
Myself when at this point, made up a "T" using a couple of 2x4's
that I could jack up against the 1/8" panel at the apex of the radius, this forced the panel to follow the radius formed by the spars
It may help if you make up a temporary cleat from scrap wood to capture the panel where the Radius meets the floor
sounds confusing but if you angle the panel in place, into the angle formed by the the ceiling and the floor, then push the panel up against the ceiling spars I think you'll get the idea
It's really pretty simple, but can be awkword thats the reason for the "T" and the jack, for a jack I reversed one of the new trigger opperated bar clamps so that it would spread rather than clamp.
alffink
Images: 37
Postby planovet » Wed Jul 23, 2008 2:51 pm
alffink wrote:I reversed one of the new trigger opperated bar clamps so that it would spread rather than clamp.
Cool! I didn't know you could do that with one of those clamps. Learn something new every day!
ImageMark (& Cindi)
planovet
The Cat Man
Postby mikeschn » Wed Jul 23, 2008 5:19 pm
An extra set of hands is a good starting point.
A bunch of sticks that you can wedge inbetween the floor and the skin...
Postby Mary K » Wed Jul 23, 2008 5:46 pm
I glued my interior roof in 2 to 3 spars at a time. Use all the clamps and scrap wood ya got.
Here is a link to more Pictures. Page 17 of my Build Pictures
Good Luck!!
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby rtp123 » Wed Jul 23, 2008 10:18 pm
Aflink: my name is Richard; Thanks for the info on using clamps and scrap bracing, I will try it this weekend. :)
mMke and Mary: Thanks for the advice; I will try again this weekend with the bracing... :D
rtp123
