Kreg on Crack?
Kreg on Crack?
Postby kiltedwon » Thu Jul 24, 2008 1:15 am
Just finished giving up on my cabinet face frame. I had some leftover Tigerwood flooring I was hoping to use, real pretty stuff. Anyway it kept on cracking and its all gone now. I'm a little surprised since I was using the Kreg system and all. All settings were for 3/4 thick wood, kreg screws, etc.
Anyone else have this problem?
kiltedwon
Images: 11
Postby Mike Angeles » Thu Jul 24, 2008 6:03 am
Hey Kiltedwon, Kreg makes a couple different types of screws, coarse and fine, If you werent already you might try the finer threads for hardwoods. Thats all I got. Sorry about the cracking,
Mike
tact /takt/ –noun
1. a keen sense of what to say or do to avoid giving offense; including the ability to speak or act without offending.
2. a keen sense of what is appropriate, tasteful, or aesthetically pleasing; taste;
Mike Angeles
Images: 76
Postby planovet » Thu Jul 24, 2008 9:05 am
The Kreg system and screws are nice but I bet using biscuits and glue would have prevented the cracking. Makes for a tight joint but it is permanent. That's just my limited experience, YMMV. But I'm not an experienced woodworker either. I sure the Tigerwood would have looked nice. :(
ImageMark (& Cindi)
planovet
The Cat Man
Postby Steve_Cox » Thu Jul 24, 2008 1:42 pm
Tigerwood is about 1.5 times harder than white oak, so to avoid splitting you just about have to drill clearance holes for screws because the cells of the wood won't compress much. Tapered drillbits work pretty well with wood screws or You could avoid screws altogether and epoxy and clamp everything together. To bad about having to scrap all that beautiful wood.
Steve_Cox
Images: 196
Postby Mike Angeles » Thu Jul 24, 2008 4:01 pm
Well you see Norm.. Errrr
FAMILY
Anacardiaceae.
OTHER COMMON NAMES
Bossona, Bototo, Coubaril, Gateado, Gomavel, Goncalo alves, Guarabu, Gusanero, Jejuira, Kingwood, Locustwood, Muira, Muiraquatiara, Mura, Urunday, Zorrowood.
Very dense and heavy wood, with a Janka hardness of 2160 (67% harder than Red Oak at 1210)
Moderately difficult to work with, especially with hand tools, with a blunting effect on cutting edges. Pre-drilling is recommended for screwing and nailing, and carbide-tipped blades and bits are recommended for power tools.
Good call on the pilot holes!
Not so sure about this one, But it did come up in Google...
http://www.tigerwoods.com
Mike
tact /takt/ –noun
Mike Angeles
Images: 76
Postby planovet » Thu Jul 24, 2008 6:12 pm
Mike Angeles wrote:FAMILY
Anacardiaceae.
OTHER COMMON NAMES
:? Will there be a test?? (I like the name Zorrowood the best)
Mike Angeles wrote:Not so sure about this one, But it did come up in Google...
:lol:
ImageMark (& Cindi)
planovet
The Cat Man
Postby looped » Thu Jul 24, 2008 6:55 pm
Very dense and,,, Moderately difficult to work with, ,,blunting.
and he plays golf too.
a friend of mine who works in private avaition when talking about dealing with him used a variation of the words jack mule many times.
"face it man. It's just not possible to fry an egg with a bicycle powered hairdryer!"
- Dave Lister
looped
Images: 31
Postby kiltedwon » Fri Jul 25, 2008 12:09 pm
Yeah, I'm pretty broke up about the wood, but also because it was my first time using the Kreg system, pocket holes and all. I guess its a learning experience.
kiltedwon
Images: 11
Postby planovet » Fri Jul 25, 2008 2:36 pm
kiltedwon wrote:Yeah, I'm pretty broke up about the wood, but also because it was my first time using the Kreg system, pocket holes and all. I guess its a learning experience.
Welcome to the club. Most of us here are on a learning curve, some steeper (like mine) than others. As long as you learn as you go it isn't a wasted experience.
ImageMark (& Cindi)
planovet
The Cat Man
Postby bdosborn » Mon Jul 28, 2008 9:01 pm
I had the same problem with maple. I started clamping a piece of scrap on the wood that I was screwing into. I put the clamp and scrap right over the area where the screw lands. This cut my cracking down to about 1 in 10 as opposed to darn near every time. Kreg also make coarse thread screws for softwood that doesn't crack as much as the fine thread but you have to back it in and out a couple of times to get it to pull tight. eBay is a great place to buy cheap pocket screws.
Images: 806
Postby kiltedwon » Mon Jul 28, 2008 11:24 pm
Yeah, I actually was using the finer screws on account of the hardwood and using the clamp as instructed. I even tested on some scrap smaller pieces, but in the end I think I'll opt to drill pilot holes for any hardwoods.
kiltedwon
Images: 11
Postby Donutboy » Tue Jul 29, 2008 12:17 am
Experience: What you get when you didn't get what you wanted.
Jerry
Retro-Kamper
(Puffin for Four)
Donutboy
Images: 126
Postby starleen2 » Tue Jul 29, 2008 3:02 am
Donutboy wrote:Experience: What you get when you didn't get what you wanted.
Experience is the best teacher, but the first lesson is not always free! :cry: :cry:
starleen2
5th Teardrop Club
Postby planovet » Tue Jul 29, 2008 8:38 am
starleen2 wrote:Experience is the best teacher, but the first lesson is not always free!
True, but usually worth it as long as no blood is involved.
ImageMark (& Cindi)
planovet
The Cat Man
Postby bdosborn » Tue Jul 29, 2008 6:57 pm
kiltedwon wrote:Yeah, I actually was using the finer screws on account of the hardwood and using the clamp as instructed. I even tested on some scrap smaller pieces, but in the end I think I'll opt to drill pilot holes for any hardwoods.
Hmm, did you try it like this?
This way holds the two pieces in position as well as cutting down on splitting. :thumbsup: This wasn't in my Kreg instructions. You might still need pilot holes but this way has worked well with maple and red oak.
Images: 806
