Marine grade materials?
Postby frogbiscuit » Mon Jul 28, 2008 11:01 am
This might be a stupid question from a noob, but having marine experience and being a boat owner, I haven't seen much on using marine grade materials. It seems if you can use 5mm marine grade plywood to skin a boat, why not a camper, and glass the outside or is this overkill?
frogbiscuit
Postby madjack » Mon Jul 28, 2008 11:11 am
froggy, the main issues are costs associated with anything labeled "marine"...your tear is not going to be sitting in water so why spend the money, when there are alternatives, which will work as well and be less expensive...having said that, there is no reason why you couldn't, since one of the great joys of these little campers is the fact you are building it, so build it to suit your tastes and needs........
madjack 8)
Postby Sonetpro » Mon Jul 28, 2008 11:11 am
It sure couldn't hurt. I didn't use marine plywood but I used all Stainless steel fixtures because we take it to the beach alot. The ones I couldn't get in stainless are already showing it after 2 years.
Sonetpro
Images: 107
Postby Juneaudave » Mon Jul 28, 2008 11:23 am
I'm a big fan of marine grade materials given the harsh weather here in Juneau. The real factor is cost and durability over time. IMHO...a well built trailer is going to last a long, long time...if you use better materials, the maintenance will be less and it will stay good looking longer.
:thinking: :thinking: :thinking:
Juneaudave
Images: 380
Postby frogbiscuit » Mon Jul 28, 2008 11:23 am
madjack wrote:froggy, the main issues are costs associated with anything labeled "marine"...your tear is not going to be sitting in water so why spend the money, when there are alternatives, which will work as well and be less expensive...
You have a point, since it can run up to $100 a sheet, depending upon the thickness...
frogbiscuit
Postby schaney » Tue Jul 29, 2008 10:07 am
It's about the trade-offs and determining what is right for you :thinking:
A void free sheet of 1088 Okoume is superior in strenght to the same thickness sheet of ABX Fir plywood.
The 1088 Okoume will be 3-4X the cost of the ABX Fir
The 1088 Okoume weighs about 30% less than the same thickness sheet of Fir. You can save additional weigh because thinner material is neccessay for achieving similar strenght
Okoume is more stable and has less tendency to crack/check over time. I have an unsealed Okoume test panel with Durabak on one side. Its been through many wet/dry cycles with no checking. A similar Fir panel would have cracks in it.
Final there is appearance if you're doing a clear finish.
If you have not guessed, I prefer to build with marine grade 1088 Okoume.
Scott
Camping the "Compact Way"
schaney
Images: 262
Postby Ralf » Sun Aug 03, 2008 1:40 pm
Marine Grade ply is pricey, but a joy to work with. I used 3/4 inch Okamie finished clear.
Fayetteville West Virginia, at the rim of the New River Gorge National River. Whitewater, mountain biking, rock climbing. One of BUDGET MAGAZINE'S TOP TEN COOLIST SMALL TOWNS IN AMERICA. Fetured in National Geographic Adventure Magazine., Noah Adams' (NPR) book,"Follow the River". Neww River George Bridge, 876 foot tall single arch. On Bridge Day sky divers jump from the bridge and live, most of the time.
Ralf
Images: 15
Postby doug hodder » Sun Aug 03, 2008 6:21 pm
If you aren't doing a strip sided woody, I'd recommend it. It's void free, antifungicidal glue and it takes on dye beautifully. I laminated it to 1/2" ACX...worked great, used epoxy. Another advantage is that a marine ply has thicker plys than a veneered plywood, less chance of sanding through the veneer. I don't use it full thickness for the walls...just laminate up a top skin of it. You don't really need 3/4" of it, just the top, go thin on the marine stuff. I also don't use cloth on it, just epoxy coating and auto clear. If you know how, it can also be bleached out to a blond appearance like the blond Chris Crafts rather than the red mahogany. Doug
Users browsing this forum: Google [Bot] and 10 guests
