not a teardrop
Postby james worley » Thu Jul 24, 2008 5:25 pm
I was not going to call it a teardrop because it did not havea rear hatch.
It will have two doors with shelves.
james worley
Images: 51
Postby james worley » Thu Jul 24, 2008 5:30 pm
Mike does it need something under the frpfor strength?
james worley
Images: 51
Postby mikeschn » Thu Jul 24, 2008 5:38 pm
james worley wrote:Mike does it need something under the frpfor strength?
I always thought FRP was brittle. A sharp stone kicked up from the car or truck tires could puncture it easily if it didn't have a substrate. It wouldn't need much to back it up. A piece of 1/8" plywood, or even masonite.
Larry talks about Filon (FRP) on his website...
http://www.outbackteardrop.com/body4.html
Of course, someone can always come along and tell me I'm all wet.
Postby james worley » Thu Jul 24, 2008 5:48 pm
Thanks mike i will check into it.
james worley
Images: 51
Postby Cliffmeister2000 » Wed Jul 30, 2008 2:31 pm
regarding substrate, bender board, maybe?
Larry's site says the frp has a maximum bend radius of 7" or greater. How tight is that back bend?
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby brian_bp » Wed Jul 30, 2008 2:52 pm
I see that it has a Bulldog forged coupler - presumably a 2B8L. These Bulldogs have a reputation for reliability, but it's a 15-lb monster with 5000 lb trailer capacity, and when I tried one of these briefly I didn't find the mechanism easy to use at all. May I ask why this coupler?
brian_bp
Images: 9
Postby starleen2 » Wed Jul 30, 2008 2:52 pm
James - glad to see ya building somethin'. Looks good - sure do miss deep east texas. Can't wait to see it finished (have to come to lufkin in sept. may stop by)
starleen2
5th Teardrop Club
Postby brian_bp » Wed Jul 30, 2008 2:54 pm
james worley wrote:I was not going to call it a teardrop because it did not have a rear hatch...
I think that's still the teardrop layout. I assumed it was "not a teardrop" because the profile is not teardrop-shaped... the tail doesn't taper down. With the tapered tail, a hatch is pretty much the only choice.
brian_bp
Images: 9
Postby brian_bp » Wed Jul 30, 2008 4:45 pm
http://www.outbackteardrop.com/body4.html ...
I think the only reason for this to be a concern is the thickness of the material. Moulded fiberglass trailer bodies are the same material, just formed in a mould instead of extruded as a sheet... but my Boler's shell is about 1/8" thick, or twice the larger of the two thicknesses (0.04" and 0.06") listed on Larry's site.
Yes, at 0.06" or less, maybe it makes sense to have a continuous support backing.
On the other hand, the same company makes Noble CTEC, which is a thick (thicker than my Boler shell) sidewall panel that would not need the backer... but I assume it wouldn't make the rear radius.
brian_bp
Images: 9
Postby brian_bp » Wed Jul 30, 2008 4:54 pm
Cliffmeister2000 wrote:Larry's site says the frp has a maximum bend radius of 7" or greater. How tight is that back bend?
I wondered about that, too. The minimum bend radius is not 7" for all FRP sheet, or even all Filon - it depends on the specific material and thickness. With all that structure and a backer panel, I suppose that a very thin (and flexible) FRP sheet could be used.
Kemlite is now Crane Composites. Some of their roofingmaterial (rather than sidewall material) bends to a 4" radius with a gelcoat (tighter without, but my guess is that most people would want the smooth finish on their teardrop).
brian_bp
Images: 9
Postby james worley » Wed Jul 30, 2008 6:42 pm
Hey brian! Yes it is over kill i'm sure,i'm just used to using them . I have
them on all of my trailers.On the radius cliff,it is around 9".I'm not 100%
sure what i'm going to do yet.Hello Scott!hope everythings going well with your move. If you come to lufkin give me a call,we can go to lunch.
james worley
Images: 51
Postby cccamper » Thu Aug 14, 2008 8:58 pm
James,
Are you bringing the new trailer to LCGIII???? Would be great to see it in person. I like it! :thumbsup:
e .. .. .. .. :relaxing:
Robert and Elizabeth - "e"
Guppy the Tiny Teardrop
"Naked people have little to no influence
on society." - - Mark Twain
cccamper
Images: 22
Postby james worley » Fri Aug 15, 2008 4:02 pm
Thank you! I will have it ready for LCGIII :worship:
james worley
Images: 51
Postby james worley » Sun Aug 17, 2008 2:53 pm
New picks
james worley
Images: 51
Postby Cliffmeister2000 » Sun Aug 17, 2008 5:47 pm
It's looking great! My wife appreciates what you did with the pre-made plastic drawers! We both appreciate the tile work! Have you ever done that before? I'm wondering how well the tile will hold up on the road?
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
