Alphacarina wrote:The only RV's I'm aware of which come with a 50 amp plug are those which use two separate roof air systems ...
Alphacarina wrote: A 30 amp plug is way overkill for any teardrop
Alphacarina wrote:The reason for the 50 amp plug isn't so much for the extra amps - A 50 amp service contains 2 separate 120 volt lines so you can run half the RV (and presumably one of the air conditioners) on one leg and the other half on the other
Don
wlooper89 wrote:I am not 100 percent sure about this but believe the 50A service can also power 240 volt appliances if the RV is wired for it, using the two 120V wires. My adapter pigtail has a four pin plug on the 50A end and three on the 30A end.
brian_bp wrote:wlooper89 wrote:I am not 100 percent sure about this but believe the 50A service can also power 240 volt appliances if the RV is wired for it, using the two 120V wires. My adapter pigtail has a four pin plug on the 50A end and three on the 30A end.
Yes, the 30A side as line, neutral, and ground pins; the 50 A side has two lines, neutral, and ground. In the 50A system 120V power is obtained between either line and neutral, and I assume that line-to-line should be 240V, just as in a similar residential circuit. I have not seen a 240V appliance in an RV, but perhaps someone has them.
ninerhb wrote:brian_bp wrote:wlooper89 wrote:I am not 100 percent sure about this but believe the 50A service can also power 240 volt appliances if the RV is wired for it, using the two 120V wires. My adapter pigtail has a four pin plug on the 50A end and three on the 30A end.
This keeps getting repeated, but it's not quite correct. 50A and 30A just refer to the carrying capacity of the wires/plugs. Either size plug/wire can come in two configurations - 120V or 240V (30A does, I don't know about 50A). You can get twice the power using a 240V plug with only one more wire, because the two legs are out of phase and thus they can share a ground and neutral line. If RV plugs are using standard 240V twistlock (or heaven forbid, stove or dryer) outlets, then they're required to supply the proper out of phase power to the two 120v poles - if they're not, they're out of code. Of course, if you get two 120v standard outlets, there's no guarantee that they're in or out of phase, or even on different circuits.
A general sort order of power is:
50A/240 > 30A/240 > 50A/120 > 20A/240 > 30A/120 > 20A/120 > 15A/120
(There is one benefit of a 30A/120 over a 20A/240 - if you want to bring your welder along and need 25A, you can't get that from the higher-powered outlet.)
HenryB
