110 and 12 volt
Anything electric, AC or DC
Postby ssrjim » Sun Aug 03, 2008 7:50 pm
This is one of those things that if you are wrong you burn down your trailer or worse.
93079
ssrjim
Postby wlooper89 » Sun Aug 03, 2008 9:21 pm
It is good to know that interference between different voltage wires is possible and I will watch for problems in that area. Something we have done already is install protective devices for the electrical circuits. These include fuses, circuit breakers and GFCI's. A GFCI protects only what is downstream (load side) so for my electrical system I decided it was a good idea to have one right after, or as close as possible to, the shore power inlet.
Bill
wlooper89
Images: 75
Postby BPFox » Mon Aug 04, 2008 6:50 pm
ssrjim wrote:This is one of those things that if you are wrong you burn down your trailer or worse.
The problem with this approach really isn't one of burning a trailer down. The problem is that the alternating current in your 110v ac line could induce a voltage spike in the 12 dc line. In most cases you are going to be ok, such as with 12 lights although you might experience some "flicker". This induced voltage could cause some damage to electronic devices that might be hooked up to 12 dc. Bottom line here is it is just not a good idea.
BPFox
Postby wlooper89 » Mon Aug 04, 2008 8:53 pm
This is a very good point. I will watch for that and if it seems to be a problem when I install the AV system I will know what to do. Many thanks!
Bill
wlooper89
Images: 75
Capacitance -vs- Inductance
Postby bobbruso » Tue Aug 05, 2008 7:47 pm
ssrjim wrote:This is not a good idea for this reason. You are turning the 12 volt into 120 volts due to capacitance.
Do you maybe mean Inductance?
I don't know how much voltage you can induce under these conditions, but you can induce an AC signal.
Any Electricians care to comment? :thinking:
bobbruso
Postby Leon » Tue Aug 05, 2008 8:30 pm
Parallel wires exhibit both inductance and capacitance.
Leon
Images: 21
Return to Electrical Secrets
