Hatch skinning wood and aluminum?
Postby shoeman » Fri Aug 08, 2008 8:31 am
I had planned on skinning my hatch with 1/8" baltic birch and .042" aluminum, but in speaking with the Teardrop fix it shop yesterday I was told that there is no need for the birch under the aluminum. The weight is the main objection apparently.
I skinned the body with just the aluminum, no under layer, and it came out fine.
Any thoughts on using just the "tin" on the outer hatch surface? I'll still use birch as the interior liner if I do it that way.
:shock:
99% of the way done with a Generic Benroy. Only because these might never be done if you like to tinker. But it's on the road!
shoeman
Images: 22
Postby halfdome, Danny » Fri Aug 08, 2008 9:01 am
The 1/8" Baltic Birch doesn't weigh that much. I used the 1/8" BB and contact cemented the aluminum skin on for a no fastener look. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Hoosier Greg » Fri Aug 08, 2008 9:42 am
Danny. What brand of contact cement did you use,if you don't mind me asking.
Beautiful job you did on your build.My hero.. :thumbsup:
HG
Hoosier Greg
Postby shoeman » Fri Aug 08, 2008 9:55 am
halfdome, Danny wrote:The 1/8" Baltic Birch doesn't weigh that much. I used the 1/8" BB and contact cemented the aluminum skin on for a no fastener look. :D Danny
Yeah, the ply in that thickness and size is light. Having it under the skin gives more to work with on the edges when it comes to trim too. But on the flip side of that using just the skin I can use his soft rivets to attach the edge trim and get a real clean install there.
Always something to worry about, aint there!
shoeman
Images: 22
Postby halfdome, Danny » Fri Aug 08, 2008 11:19 am
Hoosier Greg wrote:Danny. What brand of contact cement did you use,if you don't mind me asking.
HG
I use whatever is available that will spray, Wilsonart is the most common. They all work just as well as any other brand. If you don't spray contact use a low nap roller and make a box that will hold the roller & roller pan (metal) with a tight fitting removable front. The roller will last up to 6 months without hardening. Thanks for the kudos, :) Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby madjack » Fri Aug 08, 2008 12:14 pm
While, I didn't use an underlay on the body, I would sure use one on the hatch...it will give you something to work with when applying trim and since the hatch gets raised/lowered/dropped, it is subject to stresses that the rest of the roof is not....
madjack 8)
Postby shoeman » Fri Aug 08, 2008 3:19 pm
That's what I was thinking too. The stiffer the better. I did the body as you suggested and it came out great! :thumbsup:
shoeman
Images: 22
Postby 2bits » Fri Aug 08, 2008 11:53 pm
I was wondering about that with the thicker AL. Mine is .040 and I can tell it is thick. Sure does blow the Masonite vs. Luan debate out of the water eh, go commando! :lol:
Thomas
2bits
2bit Member
