KDOG wrote
Awesome work guys. Do you think it would be possible to design a standie that would weight less than 1,000lbs?
jml79 wrote
I love the design work on the door but in the interest of simplicity I would just leave it small. I have used this arrangement on a truck bed camper with a pop top and it worked fairly well. I am not traipsing in and out of the trailer that often and I would also be able to just hop in for a sleep without raising the roof if I wanted. Just my take but beautiful work guys
As of now my estimate for trailer weight on my future build looks about 1200lbs. That's holding the weight down as much as I can. I will use a sandwich construction every i can.
KDOG wrote:
Ugh. Hmmm, I guess I got more thinking to do...
mikeschn wrote:This is just about the smallest package I can come up with as far as the floor plan goes.
It's 66" wide, and can be built on a HF 4x8 trailer, if you stretch the trailer a little bit.
The bed can convert into a table like the Generic ET. The bathroom is also similar to the Generic ET, only instead of being 36" wide, it's only 30" wide.
The space between the bed and the storage counter is only about 26" so it's pretty tight there too. Both the entry door, and the bathroom door can be 24", although I wouldn't recommend a door for the bathroom. A curtain might be a better option. Oh yes, it's a dry bathroom with a porta potty. No shower.
I'll start on the profile next.
KDOG wrote:Well that looks good. I'm wondering about interior height as well. I don't need much since I'm 5'5". I also am not going to put a galley in - just walls, floor and ceiling as far as the basic design so that should eliminate some weight. How much space do you think the porta-potti requires to be useful? 2.5' x 2.5'? Is that a ledge in the bathroom to elevate to potti or is there a storage tank under there?
KDOG wrote:Ok, I couldn't figure out what you meant by chassis at first, but thats a footwell where the potti is right? and the ledge is the frame of the trailer correct?
KDOG wrote:Thanks Mike. Can you make a quick profile for the design you came up with a few posts up? I'm dumb and don't have a CAD program.... To be under 1,000lbs, its going to have to be built as an ultralight. Think it can be done?
