by boardhead » Sat Aug 16, 2008 12:28 pm
After you bolt your floor to the frame, fill in the holes with the bolt heads with epoxy or similar.
I had to remove the body of my tear from the frame after being rear ended. Removing the nylox nuts, without access to the bolt heads, was a huge pain because the bolts kept turning. After raising the body, removing the bent up Harbor Freight trailer and replacing it with a new one, replacing and tightening the nuts was again extremely difficult.
Sealing the bolt heads during the build with something to keep them from turning would have saved me at least two days of work during the rebuild.
