Thanks,
Sherry
S. Heisley wrote:According to Andrew's weight chart, a gallon of water weighs 9 lbs. I weighed a gallon of water and found he was absolutely correct.
Allowing maybe a 1 gallon air space at the top, 20x9=180 lbs.
Other than the obvious mechanical tow-ability, I believe the TD and TTT builder has 3 major concerns to keep in check: weight, space usage, and water leaks. (Then, there's batteries, electrical, propane.....)In my opinion, this makes strategic planning of one's build nearly mandatory.
...Of course, there is that saying: "The greatest plans of mice and men oft go astray." (Oh, good grief! I hope not!)
Best Wishes,
Sharon
My trailer weighs 1600 lbs, so if my tongue weight is 10%, that makes my tongue weight 160 Lbs, which is kinda heavy for me, so if I added a 180 Lbs water tank under my galley, maybe my tongue weight would go down!!
SherryB wrote:I bought a 21 gal polyethelene tank with 3 threaded 3/8" connections and one 1 1/4" hose fill barb to attach a 1 1/4" hose. The tank has no fittings and I would like to mount the tank flat and be able to fill the tank as well as pull water out of the tank to a faucet several feet away, as well as drain the tank. I need suggestions for all parts. I am building a 5 x 8 teardrop and want to be able to have faucet in galley area and be able to pump the water out of the tank to the faucet.
Thanks,
Sherry
[img]http://www.mikenchell.com/forums/album_personal.php?user_id=7593[/img]
[img]http://www.tnttt.com/gallery/image.php?image_id=40069[/img]
SherryB wrote:Thanks for all your input. I have found what I need from JCWhitney. Yeah!
