coreyjhen wrote:I found a serious flaw in my construction and now need to go back and fix it. Does anyone have a safe, easy way to split apart a Titebond III joint without destroying all the underlying surface? I have searched the archives and not found anything... but it could easily be that I haven't searched on the right keywords.
Steve_Cox wrote:Depending on the type of joinery, I have used a sawzsall with a fine blade to separate glued parts.
aggie79 wrote:Could you say what you are trying to correct? My thought is that it may be possible to remove just a portion of the skin to get to the structure for the repair.
coreyjhen wrote:It's the outside walls - they're off by over a quarter of an inch, so nothing will line up. They're glued and screwed to the floor.
