by doug hodder » Sun Jun 12, 2005 12:35 am
Just an idea for those of you routing aluminum. an upcut or down cut bit helps to minimize galling on it also, It pulls the chips out of the way and allows a clean cutting face on the material. We used them in the sign industry, 1/4" shank and routed 1/4" material all the time with them, They are available in double ended models also. Not from home depot however, gotta go to an official tool supplier. I've used them a lot, they have 4 flutes to them....I haven't bought one in years, I just used all the leftovers from the sign shop.. They aren't available I don't think with a pilot bearing however. you will need to build a jig...Doug Hodder
