mechmagcn wrote:2bits wrote:tinksdad wrote:Ask a knowledgeable salesperson.
My thoughts exactly, there are no such persons at our local HD
You can do it. They can't help.
2bits wrote:I was thinking of drilling out and through the wall but that means buying a long drill bit and drilling down into the plywood, not my first choice! My working idea is to just put a small piece of vertical stained trim straight to the roof with the wire underneath. Not perfect, but not completely unsightly either. Somebody might think it is manufactured then tho![]()
2bits wrote:
Sparks, check out my post where I posted the pic, I actually asked that same question. I am going to run a wire straight up to the roof with a piece of trim covering it unless I get another idea between now and then.
I won't get to work on it again for a couple days though
S. Heisley wrote:Hi, Thomas:
It might look nice if you made the electrical line look like a feature of the lamp and instead of trying to match your TD walls. In other words, run your wire up the wall to a small wire-sized ceiling opening and cover the wire with 'wooden' tubing that has the same color and type of woodgrain design as the lamp. Or, use a piece of metal tubing that matches the brass/silver(?) in the lamp. That way, it'll look like it was meant to be that way and you'll have minimal damage to those beautiful walls, should you decide to change things later.
...Just the 'decorator' coming out in me...TeeHee!
Sharon
2bits wrote:S. Heisley wrote:Hi, Thomas:
Sharon
I was intrigued by the router idea alot but then coverage is still a choice to be made. Sharon, I think you hit on what works for memake it look like part of the lamp assembly with some similar metal. Excellent! thanks!
