ok..i think i am pretty set on having just a charger in my power plan...having the battery run all of my devices and just having a few 110 outlets off of the initial shore power. I have a question...that i think I know the answers too but would feel a lot better if one of you geniuses could comment.
this is what I came to in another post after much help from the group
"so the shore power comes in...it has your normal 120 outlet..the charger plugs into the outlet and then runs to your battery? your battery in turn running back to your fuse block which in turn goes out to your lights and etc...is this correct?"
Where shall I keep the charger? I would prefer to keep it in the raceway under the cabin cabinets with most of the other wiring. If I do this, I will need to run the leads from the battery tender to the battery...is it safe to do this through the walls just like i will do the normal wiring? Are the wires that come from the charger just "normal" electrical wiring? Also, if i do this, I can just plug the charger into the first gfci i will install after the shore inlet correct?
thanks again...
mandy
