1/2" walls......anyone done this?
Postby surveytech » Fri Jun 10, 2005 7:54 pm
Anyone done their walls with just 1/2" plywood? I dont mean using 1/2" in a sandwich construction but 1/2" ply all by it's lonesome self.
Do you think it would be rigid enough to be able to make a removable galley?
I am trying to preserve some of the "utility" function of the trailer if possible and if part/all of the galley could slide out it would be ideal for our use.
Thanks to all!
Walter
surveytech
Images: 6
Postby McTeardrops » Fri Jun 10, 2005 8:38 pm
Gasolene Alley Teardrops builds theirs with 1/2" plywood sides, and a single layer of 1/4" on top. Seemed fairly sturdy, just from climbing in and out, and swinging doors. They showed me a ten-year-old unit still in regular use.
Lenny
[email protected]
I've reached the stage, in life, where my foam has more memory than I do!
McTeardrops
Postby SteveH » Fri Jun 10, 2005 9:31 pm
I have a friend here that has an original 1947 Kit teardrop and they are built with 1/2" plywood walls and floor. The roof is made with masonite covering the spars with aluminum on top. Must be OK as it is still in very nice condition.
SteveH
SteveH
Images: 42
Re: 1/2" walls......anyone done this?
Postby GeorgeT » Sat Jun 11, 2005 11:56 pm
surveytech wrote:Anyone done their walls with just 1/2" plywood? I dont mean using 1/2" in a sandwich construction but 1/2" ply all by it's lonesome self.
Thanks to all!
Walter
I built mine with 1/2 plywood walls that are not sandwich constructed. Rock sturdy. Lookey here http://home.earthlink.net/~g.teague/
Lookin' up in da skize with ize on da prize
GeorgeT
Postby fornesto » Mon Jun 13, 2005 7:02 pm
Mine is 1/2" plywood. The extra 1/4" doesn't really do that much except add weight. The forces exerted on a teardrop are on the whole structure, not just the sidewalls. A good box-like construction is better than heavier sidewals IMHO. I also feel that heavier sidewalls will put more stress on the spars and spar screws as it enevitably rocks back and forth. Again, heavier can be your enemy.
fornesto
1/2" plywood TD
Postby Finntec » Mon Jun 13, 2005 8:18 pm
I am building ours with 1/2" sides. All I have left is to finish the galley and attach the doors. I found that the 1/2" sides have been very sturdy once you put the roof on. When I build another one, I will use 1/2" again.
Former owner of a '05 Homebuilt TD & '87 Scamp
2012 Home built 10' Teardrop.
Finntec
Images: 28
is that a pep boys frame under your tear?
Postby surveytech » Tue Jun 14, 2005 3:28 am
Ray and Debbie.
is that a pep boys trailer frame kit under your tear? It looks very much like the trailers at Tractor Supply except for a couple of minor details.
How has it been working out for you?
Thanks for the info on the 1/2" ply. I think thats what I am going to do as well.
Walter
surveytech
Images: 6
Postby Roly Nelson » Tue Jun 14, 2005 1:07 pm
Walter, they make airplanes out of 1/8" plywood, so I built my woody sides out of 1/4" lauan, which is really only 3/16" thick! I have all of the openings lined with 3/4" pine, and when I jack up one rear corner, lift the wheel off of the ground, the doors work just fine. Of course the galley cabinets create the stiffness required to make the whole box unflexable. 2 layers of 1/8" were used on the roof, with the good sides facing out. 1/2" sides should not cause any problem that I can think of.
Roly, varathaning again for the Minden trip. :-)
Roly Nelson
L'il Ol' Woody Builder
Postby darockrider » Sun Jun 19, 2005 10:20 pm
My first teardrop a smaller than normal for motorcycle towwing has 1/2" sides. Once the roof was on and the skin glued into place it is very strong and very rigid. Just use care when attaching fender and windows and door frames as you have alot less wood for the screws to bite into!
Definately lighter by 50% over 3/4" and also much cheaper!
just my 2cents worth
Gerald
darockrider
Images: 25
