cleaning welds for painting
Postby Muggnz » Tue Sep 09, 2008 3:24 am
hi,
how do I best cleaning welds for painting? I plan on using Hammerite Direct To Rust Metal Paint.
Is there way to do this, without having to resort to the wire brush method?
The welds have been created by a gas fired MIG welder.
thanks
david
Muggnz
Crybaby
Images: 34
Re: cleaning welds for painting
Postby Larwyn » Tue Sep 09, 2008 8:04 am
Muggnz wrote:hi,
thanks
david
Well, I use a 4.5" angle grinder with a cup brush and then wipe the steel down with a rag soaked in denatured alcohol. Seems to work good enough for me.
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby Mike Angeles » Tue Sep 09, 2008 8:41 am
Flap disk on your Grinder, cleans up very nice
tact /takt/ –noun
1. a keen sense of what to say or do to avoid giving offense; including the ability to speak or act without offending.
2. a keen sense of what is appropriate, tasteful, or aesthetically pleasing; taste;
Mike Angeles
Images: 76
Postby Joe G » Tue Sep 09, 2008 9:46 am
Nothing beats a sandblaster. But short of that, do exactly what Larwyn said.
Joe G
Images: 25
Postby Dale M. » Tue Sep 09, 2008 10:04 am
Gas shielded MIG welds should be clean to start with, should not need any special preparations.. Just prep as rest of materials that make up frame and paint. If using "flux" core wire, use various methods described above to remove flux/scale....
Dale
Dale M.
Images: 18
Postby asianflava » Tue Sep 09, 2008 2:43 pm
We used a wirefeed MIG on my frame. It wasn't nearly as dirty as another project when we used flux coated wire on a stick welder. Whe had to use a chipping hammer to clean them
I cleaned mine frame with laquer thinner prior to paint. I also used Rust Bullet paint.
asianflava
Postby Steve_Cox » Tue Sep 09, 2008 3:56 pm
I did the cup brush on the 4 1/2" grinder, and washed the steel with acetone, since that was what I had handy. Painted with red primer then Hammerite.
Steve_Cox
Images: 196
Postby Muggnz » Wed Sep 10, 2008 2:33 am
thanks everybody.
I've got a couple more welds to go before final cleaning & painting.
After that I guess I get to watch paint dry, harden & ablate.
david
Muggnz
Crybaby
Images: 34
Postby Muggnz » Mon Oct 20, 2008 3:52 am
after all the fuss & botheration I went through to get this far. I decided to try the wire "brush" wheel attached to my electric drill. Just to see what it'd do. And was suprised. It removed ALL the rubbish in & around the welds. & polished the metal very nicely. So half a day later I had a nice polished chassis.
I used white spirits ( AKA lighter fuel ) to rub down the metal before painting. Using an old toothbrush to get into the depths of the welds.
david
Muggnz
Crybaby
Images: 34
Postby frank_a » Thu Sep 02, 2010 6:01 pm
I clean stuff up, then dress welds with a bit of body fill, let it dry, sand smooth, clean again (usually NAPA's Kleanz-Easy), then prime and paint.
Frank
Tiny travel trailer - 1979 Sunline Sunspot. Tow vehicles: 2008 Subaru AWD Outback, 2009 GMC 4WD Canyon. For fun: 1923 T bucket hot rod, 1962 Power Cat tunnel hull speed boat. 1974 Dodge Dart waiting for renovation.
frank_a
Images: 34
