Well, summer has finally arrived here in New England, though the spring rains seem to have found a permanent home. Not much progress over the winter, but have gotten in a couple of days of building in recent months. The rear roof section is just about complete with framing, skinned, skylight and lift mechanism all in place. Am waiting to paint until the front section is done. Was able to jury rig a "garage" for the build using a 10X10 EZ up canopy and tarps for side walls which makes things a bit easier but still seems like too much to do and not enough time. I've rethought my timeline and my new one is whenever I get it done. I've recently updated the diary and pictures on my web site
www.aframecamper.homestead.com
Was able to use the existing spring assisted lift arm on the rear roof, when its lifted fully into place and locked it holds the roof just fine. The spring assist is heavy enough that I can literally lift the roof into place with 1 finger. The front lift because of the way its hinged at the pivot point I am not sure will work. Need to get the front roof section completed and opened fully to see if I can make it work, otherwise its gas shocks for there. On the rear I will cut down the lift arm so it dosen't stick up so far. Moved a bit farther on the front framing after this pic was taken and have framed in for 2 14"x14" operable roof vents. Still a lot of fun working on the build, now just have to find the time and the extra $ for the materials. I'll continue to post and update the web site as I get farther along.
