Basic Dual Filament Bulb Question
Postby fornesto » Fri Jun 17, 2005 4:19 pm
Is the brighter of the dual filaments supposed to be for the turn and brake lights and the dimmer for the taillights?
My turn and brake lights are very dim and my taillights are very bright. When the taillights are on with the headlights, you can hardly notice the blinking of the turn signal = ticket in CA. If I switch the two wire leads, will this reverse the problem?
The lights are the '39 Ford style.
fornesto
Postby jgalt » Fri Jun 17, 2005 5:35 pm
My understanding is that the brake light should be the brightest. This is the one that needs to be the most visible for safety reasons.
jgalt
Postby Chuck Craven » Fri Jun 17, 2005 5:39 pm
:yes:
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby asianflava » Fri Jun 17, 2005 6:10 pm
I think that when you hit the brakes, both filaments light. During tail light only one is lit.
asianflava
Postby Chuck Craven » Fri Jun 17, 2005 6:34 pm
No the tail light is the dimer filiment and the stop/signal is the brighter filiment. Check this out http://www.etrailer.com/faq/wiring.asp
Chuck
Chuck Craven
Images: 62
Postby Ken A Hood » Fri Jun 17, 2005 6:42 pm
You might also try a "Heavy Duty" flasher. I know when we had a popup trailer, my dad had to get 1 since the lights were dim, and very slow to blink.
Disclaimer: I in no way resemble the avatar shown. Furthermore, I in no way have any affiliation to the Trailer Park Boys and more specifically Bubbles!
Ken A Hood
Images: 42
Postby doug hodder » Sat Jun 18, 2005 11:05 pm
Something else to consider. I bought aftermarket 40-54 GM taillights for my tear. The inside of the housing was painted black, no reflectivity. I sprayed them gloss white and that made a big difference. Yes, switch the wires, and no, both filaments typically do not illuminate when the brakes are applied, This is only the case if the lights are on and you apply the brakes. Doug Hodder
Postby Woody » Sun Jun 19, 2005 5:44 pm
I would check for a bad ground, Sometimes when a ground is bad the lights are dimmer
Woody
E-mail: [email protected]
Woody
Images: 26
Postby fornesto » Mon Jun 20, 2005 12:12 pm
switched the wires and we're A-OK! I might try the heavy duty flasher just to be safe.
fornesto
Postby ScottH61 » Mon Jun 20, 2005 10:04 pm
fornesto wrote:switched the wires and we're A-OK! I might try the heavy duty flasher just to be safe.
Get yourself an electronic flasher... it regulates the flash depending on the load. That way when your trailer is disconnected, the turn signal won't look like a stobe light. :-)
~ Scott
ScottH61
Users browsing this forum: Google [Bot] and 1 guest
