Thanks
James
Donutboy wrote:Just curious...why does it need the tongue reinforced? I have a TSC trailer as well; want to make certain I haven't missed anything.
angib wrote:Scott, you've identified an alternative solution, which is just to reinforce what's there. Welding all joints will add strength and if you've got a strong floor (like 3/4") then the bolts will add that strength to the frame - an alternative is to add an extra piece alongside the second cross-member.
For those who want to avoid any welding, an extra angle placed back-to-back with the cross-member and bolted in several (eight?) places would add the strength needed.
Andrew
