annalbs wrote:ahem...i do think you are overthinking this... the fenders will look good once the trim is on.... besides aren't i always right about these kind of things...
I had planned on letting them hang lower than the body because i was going to build a bracket to bolt them to the frame.. You think it would help if i cut them off even to the body? Front and back or just front?madjack wrote:...haven't voted yet..is that the position they are going to sit...if so, they appear to be too long and need to be cut down so they end at the edge of the body line...if the color is off...to you, there is always paint...
madjack wrote:Eddie, it is hard to tell exactly because the pic is not straight on but they look too close to the tire(or they sitting onit for now)and to me,look a little too long...do they get raised any? can they be mounted to the wall? they just look too low as shown...if I could mount them to the wall, I would and shorten them front and back.....
Dean_A wrote:I see what you mean. Your TD has such a long, sleek profile that you want the fenders to match. I think it will look much better with the diamond plate trim, as it will tie into the fenders and accentuate the horizontal lines. Mad Jack's suggestion was a good one too. Chop off the extra fender. It will shorten the vertical height and make them look a little "faster".
Here's what it would look like:
I think it's an improvement.
