CrocTears wrote:
Is there a slick way to make a template of a large curved surface that you need to match? All I can think to do is slog through it with cardboard.
Hold a 1x6 1x8 or 1x10 depending how sharp the curve against the ceiling as near even as you can. (If you level the trailer you can level the board) I use a childs wooden abc block with a small notch sawn in for my pencil. Now drag the wood block across the ceiling and with pencil inserted in the underside notch simply trace.
