Leaf Spring Repair
Leaf Spring Repair
Postby CaptainKram » Thu Oct 16, 2008 1:04 pm
My leaf springs are in pretty rough shape. I plan on media blasting the rust off, and replacing the u-bolts. I read somewhere that the leafs should be separated and a thin layer of grease applied between each when replaced. Is there a tool or technique for getting these things apart? I haven't tried yet, I just figured I'd ask before I tore up a couple of screw drivers or chisels trying. :roll: :roll:
CK
"A woman drove me to drink, and I didn't even have the decency to thank her." ~W. C. Feilds
CaptainKram
Images: 6
Postby doug hodder » Thu Oct 16, 2008 1:44 pm
If your springs are in pretty rough shape, I wonder if it's worth the time and effort to rehab them or just go get a matched pair of new ones. They aren't that much. You never know. They may have been overloaded at one time and are beat. Typically, they are rivited together and might just make for real headache. Just an idea. Doug
Postby Miriam C. » Thu Oct 16, 2008 3:58 pm
doug hodder wrote:If your springs are in pretty rough shape, I wonder if it's worth the time and effort to rehab them or just go get a matched pair of new ones. They aren't that much. You never know. They may have been overloaded at one time and are beat. Typically, they are rivited together and might just make for real headache. Just an idea. Doug
:thumbsup: what he said. It is much easier to do them before the TD is on top and while you already have it apart.
Postby starleen2 » Thu Oct 16, 2008 5:17 pm
Robert Hesselmann's blog spot has an article on axel rehab that also covers leaf springs
http://vintagetraileraxle.blogspot.com
starleen2
5th Teardrop Club
Postby CaptainKram » Fri Oct 17, 2008 7:59 am
starleen2 wrote:Robert Hesselmann's blog spot has an article on axel rehab that also covers leaf springs
That's the one I was looking for :thumbsup: thanks starleen.
Doug & Miriam C., That might just be the way to go. I'll see what I see once I get them off the axle. :roll: ;)
Also, any recommendations on which way to go with brakes (elec., surge, etc)? I really don't know that I'm going to need them yet but I'm trying to look ahead and do this right the first time :thinking: 8)
CaptainKram
Images: 6
Postby madjack » Fri Oct 17, 2008 9:22 am
CK, with the low cost of springs, if I had any questions at all about the old ones, I would get a new set...as too brakes, I am firmly in the electric brake category...some like surge but with the newer fully proportional, digital controllers, they are pretty much a "plug & play' item.....
madjack 8)
Postby Rigsby » Fri Oct 17, 2008 3:51 pm
IMHO i would never use electric brakes. All you need is a loss of power and youve got a loss of brakes. If i am building a trailer with brakes, i always use a overrun brakes from a sliding hitch. I think our european laws regarding brakes on trailers are a little more stringent than in the US. Over here , it has to have overrun brakes if the gross weight exeeds 750kg
DOOIN IT THE YAARKSHA WAY--FA NOWT, THA NUS !!
Rigsby
