Mark
So sexy!!!
rhltechie wrote:
and DANG man, thats a lot of poly/sand/stain!!!
I have promised to carve pumpkins tonight, so another night will go by with no TD work...more tomorrow night I am sure. but it sure is gettin cold out there!
The time you are taking now for the cpes will give you peace of mind on down the road.
rhltechie wrote:Lesson learned today:
1. PATIENCE PATIENCE PATIENCE - so hard for me
2. tools are really important
3. do it right the first time and you wont have to spend 2 hours trying to take an 1/8 of an inch off somewhere
Are you undercoating it with the black goo (Asphalt emulsion)? If so, you will want to let it dry for a day or so before putting everything on the trailer. Also, don't forget to seal the bolt holes from fastening it down. I used polyurethene caulk between the trailer and floor frames and also put some in the bottom of each bolt hole that I drilled through the wood to keep it sealed.
rhltechie wrote:Are you undercoating it with the black goo (Asphalt emulsion)? If so, you will want to let it dry for a day or so before putting everything on the trailer. Also, don't forget to seal the bolt holes from fastening it down. I used polyurethene caulk between the trailer and floor frames and also put some in the bottom of each bolt hole that I drilled through the wood to keep it sealed.
Yeah, I am using the black goo. I figured after I put it on it would take a few days to dry. When you say seal the bolt holes, do you mean with cpes or this caulk you are talking about? Put caulk between the trailer and the floor frame, not sure I understand that part. I understand putting some in the bolt hole...very good advice..not sure i had thought that far.
