I am not finnished and may have more to add as I go.
1 Get a trailer frame made or learn to make
and old one has rust and you have to get new wheels and brakes
if it needs them or has them you'll need to replace
why not start all of it new.
2. investate all windows and doors before you cut.
preplaning will be the best more
3. what do you want to put inside. Sound, ac, power (12 or 120 or both)
4. try to look at as many trailers as you can
primarly the type you plan to build
5. get or find as many plans as you can
without spending alot of money alot of money.
6. do lots and lots of drawings
show what you like on the forum
and they will tell you what will work best.
7. even if they don't like it it may be what you do so make sure
above all else it pleases you.
mine is a simple trailer I can sleep in it. It is farly light, I can use 12 volts I have wired for sound. I lack many of the shop skills that other builders have and so my trailer is very rouph. I am not bothered that the guy next to me has one that looks like it was manufacured. i made mine as best as I can and am learning as I go how to do what I failed to do before. it. took me 4 years to get this far and now if I were to redue it I could so it in 1 yr.
So the more you know the better the end result of what you wanted to get will look and become what you wanted and if not.
many of these folks have ripped out part and redone new ideas, many have sold the first one and rebuilt not 1 but 4 or 5.
what matters is that you have fun doing it. and you go out camping more often and find out wht a DOG is and if you smell waffels Doug is cooking in his fancy chef's pants in his dream kitchen in his second build and you should have seen the first one.
don't be afraid it will grow on you and then you will be hooked.
Filled with tears of happiness.
