len19070 wrote:If I build a 4' wide trailer I use a 3/4" solid side covered inside with a "Foam Backed Rug" for a few reasons.
The main reason is that 46.5" for an inside dimension is narrow enough, I see no need to make it any narrower just to accommodate a thicker wall.
But the thicker framed wall is insulated
You may say, Yes...what is its "R" factor? About "R"7 if 1" Styrofoam is used.
What is the "R" value of 3/4" Plywood covered with a foam backed rug?
Nobody knows, but I'll bet its real close to "R" 7.
But the framed wall is lighter
Really, I'll bet 2 sheets of 1/4" plywood, all the framing lumber, nails/screws, glue and Styrofoam weigh almost the same as a sheet of 3/4" plywood.
Now, on a Wider than 4' build where I have the width I'll use a stick built wall 2" wide and really Pack it with insulation.
JMO
Happy Trails
Len
NWsage wrote:Our TD has an insulated top, but the sides are not insulated. They are 3/4" plywood. I've gone camping twice this fall where the nighttime temps dropped below 40F. The sides had lots of condensation, but the ceiling didn't. I wish our trailer had insulated sides. Suanne
doug hodder wrote:For those of you that have condensation problems, do you crack the top roof vent at night? Doug
