Woody wrote:my experience with spar varnish is once it is open, it ages, it gets alittle darker as the the violatile components start evaporating and it is exposed to air. The color change is not that dramatic of a shift just a little deeper amber color. You can run into problems with not mixing it once in awhile and get sheen differences, those are slight. Tempeture and relative humidity does affect curing times not color
I think IraRat's problem is mismatched wood, not from the same tree, it is as simple as that.
doug hodder wrote:by the way your name came up several times in Minden, all good things too!! Doug Hodder
IraRat wrote:A lot of the joy seems to be in the planning, buying stuff and the building of it.
Dean in Eureka, CA wrote:IraRat wrote:A lot of the joy seems to be in the planning, buying stuff and the building of it.
Build... sell, build... sell, repeat as necessary.
