vrooom3440 wrote: So why not just avoid the potential for problems completely by using stranded copper rather then Romex?
The most likely failure mode with Romex and regular house electrical outlets would be a poor connection from the typical method of inserting wire into outlets. The design of 'stick it in' connections was never intended to handle potential movement of the wires.
there are other types of wire out there which are much more suitable to TD usage than Romex. They are not hard to find nor much more expensive.
But hook up an electric heater and that may change... remember that heating in a circuit is proportional to the *square* of the current multiplied by the resistance. So a 1500W heater pulling 12.5A with a 1ohm resistance in a connection generates over 150W of heating. That is enough to cause some issues
48Rob wrote:About the worst vibration you'll get in a td is a young couple who left the kids with grandma for the weekend...
bobhenry wrote:vrooom3440 wrote: So why not just avoid the potential for problems completely by using stranded copper rather then Romex?
Wire Nuts. The don't work with anything but solid-core, so see item 1. Crimp connectors are easy and secure, and if you have any question about exposure to the elements it is easy to cover them with heat-shrink tubing.
I didn't say it see above !!!!
I used stranded wire from a 12 gauge extension cord. I used forked terminal ends mounted solidly onto the screw terminals of the duplex outlets. Never liked the stab in and hope it connects in the backs of the duplexs and switches.
HOWEVER many of the grouping connections are made with wire nuts With only 1 problem. Had 12 ground wires in one connection and wire nut was way to small. Went to a grounding bar out of a fuse box and no further problems.
