How to do a 5x8 on a 4x8 trailer
Postby zlamb0002 » Thu Nov 13, 2008 4:35 pm
I already have a 4x8 harbor freight trailer. How do I put a 5x8 floor on it, I would like some pictures see so I can make for sure I understand how to do it.
zlamb0002
Postby dmckruit » Thu Nov 13, 2008 5:36 pm
Check out my build thread "Red Dragons - The Build" and you will see by the end of the weekend. I just finished up my trailer modifications this morning and will start to put the floor on tomorrow. I took a few days off to work on my tear. I couldn't find my 5/16th wood drill bit, so I have to run out in the morning to get another one and a few sheets of plywood for the interior floor.
http://www.tnttt.com/viewtopic.php?t=26538
dmckruit
Images: 212
Postby len19070 » Thu Nov 13, 2008 7:43 pm
I did a 65" wide on a HF frame with a small dropped floor. I went 65" and over the wheels, because it went totally over the fenders as well, it also accommodated 2 "Junior Twin" size mattress's (32" wide) with no "Lumps" for the wheel wells.
http://s26.photobucket.com/albums/c106/ ... %20shasta/
Happy Trails
Len
len19070
Images: 24
Postby Dale M. » Thu Nov 13, 2008 9:10 pm
Simply let floor hang over all the sides (frame rails) by 6 inches and set walls on floor....
Dale
Dale M.
Images: 18
Postby satch » Thu Nov 13, 2008 9:21 pm
I overhung the sides 6", but on the length, I took 2 of the crossmembers and put them where the two center pieces met and extended it 1 foot. Just had to redrill new holes, and used a 2x4 to make up the lost crossmember. I have some pics in my album, but it may not show where the extension is.
If it itches. scratch it
Rick
satch
Images: 63
Postby Bigwoods » Thu Nov 13, 2008 11:35 pm
This is how I did it. We extended the axle 6" on the side and the carraige carries the side panel. I ran wood to the front and the rails can not be seen. Now that I done, I am pleased with the results.
Greg in Northern Minnesota
Bigwoods
Images: 104
Postby Toytaco2 » Fri Nov 14, 2008 7:50 pm
I went 5 wide on my HF frame. Its really unusual because I went 5 high as well. Just build the floor out over the top of the wheels and build in wheel wells.
Here's the floor before anything else what done (I later removed the fenders):
and here's what the wheel wells look like:
More pictures in my album of the floor and frame.
Good Luck,
Mike
Toytaco2
Images: 368
