I'm 6'6", the Mrs is 6'2" and the twins will become large.
Do you drop the floor to get leg room for the poo box or just stay standard and go for simplicity?
Frame is 5 x 10.....wheels outside.
mk10108 wrote:With the help of Mike, I rounded some curves and came up with this.....
angib wrote:mk10108 wrote:With the help of Mike, I rounded some curves and came up with this.....
One thing to check with this profile is how you will build it: the front and back bottom corners are very tight - about 6" radius - so if you are planning to carry the roof right under the floor, you will need thin bendy ply down there.
Many bodies are built with the bottom 3" or so of the sidewall just hanging below the floor on its own, with the roof skin stopping above the floor and in that case those very tight radiuses are mostly below where the roof skin ends.
Andrew
