Miriam C. wrote:The stranded is easier to work with and unless you are using the more expensive stab in receptacles, stranded is so much easier to wrap around screws. I think that is the only real reason to use it over something else.
Alphacarina wrote:Miriam's 'proof' that stranded wire carries more current that solid wire:
Stranded vs. Solid Wire
"This one is a bit of a mind-boggler, but it's important. When electricity flows through a wire, it mostly flows on the surface of the wire, not through the middle. This effect is more pronounced on high frequency AC than it is on DC or low frequency AC...
wlooper89 wrote:With my Hubbell power inlet there were instructions not to tin the wires before inserting in the holes for them in the inlet housing
Arne wrote:tinning basically turns a stranded wire into a solid wire. where the transition takes place can be a problem if not properly supported.
I don't think it is a 'big deal', but it is a 'deal' and has to be taken into account.
Miriam C. wrote:If you think you will have a vibration issue then by all means use stranded. Only you know how and where you will be towing. I take mine down some pretty washboard roads and it even survived I-20 out of Shreveport LAAlthough I wasn't sure for a while there.
starleen2 wrote:Miriam C. wrote:If you think you will have a vibration issue then by all means use stranded. Only you know how and where you will be towing. I take mine down some pretty washboard roads and it even survived I-20 out of Shreveport LAAlthough I wasn't sure for a while there.
I thought i was the only one who had that problem on I-20?
Alphacarina wrote:True, the skin effect is much less at low frequencies like the 60 Hertz we use, but it's still a factor with any frequency and is one of the advantages of using stranded wire - It's one reason why high tension cables used for transmssion lines are always composed of bundled wire and not a single conductor
wlooper89 wrote:I am very curious about the objection to tinning the ends of stranded wire. Why is it a can of worms?![]()
Thanks, Bill
