Larwyn wrote:Analog "ammeters" and "voltmeters" are actually all ammeters. The external circuitry and meter face scale are what makes it indicate amps, volts, etc.
http://www.electronics-tutorials.com/test-equip/meters.htm
4123 wrote:I think that a DC analog charge/discharge amp meter will tell you when your battery is fully charged. That is, if you have been parked for an extended time and want to charge your battery using your tow vehicles regulated charge system, when the battery is fully charged the gauge will read 'zero' and you can turn the motor off. Is it so?
