How to cut openings for doors with rounded corners
Postby zlamb0002 » Wed Nov 19, 2008 12:28 am
I was looking for doors and most of them I have found have rounded corners and I was wondering how to cut openings for them. I am not to good with a jig saw so I was wondering if there was an easier way to do it.
zlamb0002
Postby halfdome, Danny » Wed Nov 19, 2008 12:36 am
I'd practice, practice, practice with a jig saw until you feel confident enough to cut the radius corners.
Watch the line not the saw when cutting and take it nice and steady. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby zlamb0002 » Wed Nov 19, 2008 1:18 am
I was just thinking, is it possible to use a box cutter? I will just be cutting through 1/8" plywood.
zlamb0002
Postby Jst83 » Wed Nov 19, 2008 5:14 am
Yep jigsaw, I don't think a box knife would do it on 1/8" plywood.
Just take it slow :thumbsup:
Jst83
Images: 215
Postby toypusher » Wed Nov 19, 2008 5:45 am
If you are cutting 1/8", I would recommend that you use a fine tooth blade (higher TPI) and cut it from the backside of the sheet.
toypusher
Images: 324
Postby Endo » Wed Nov 19, 2008 7:44 am
zlamb0002 wrote:I was just thinking, is it possible to use a box cutter? I will just be cutting through 1/8" plywood.
I used a box cutter to cut out my roof vent opening through 5.2mm luan plywood. It was straight cuts only. It took multiple passes along a metal straight edge and a fair amount of pressure. It was a nice clean cut but really alot of work. I'm not sure I would want to try and follow a curve with a box cutter.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby Dean_A » Thu Nov 20, 2008 1:49 am
You can always do a rough-cut with the jig saw, then go back with the belt sander and finish it off.
Dean_A
Images: 55
Postby John Bailey » Sat Nov 22, 2008 10:48 am
I would think most doors have some kind of trim, so being off a hair may not matter that much. A jig saw is really the way to go. With the pressure you'd have to use with a box cutter, I think your chances of hitting the line would be better with a jigsaw. Toypusher's advice is great, and I would add, scoring the line will help with tear-out.
If you really want a clean line, you'll probably have to use a circle cutter with a router with the correct radius. Seems like too much work to me though. I've also used a jig cut to the proper radius on a band saw, then used it to guide the router. Again, a lot of work to get something exact that's going to be covered. Keep in mind, I'm not a tear-dropper. (yet)
John
John Bailey
Postby glider » Sat Nov 22, 2008 11:11 am
Router, jigsaw, rotozip or maybe chain drill using a small bit then join the dots and finish by wraping sand paper round a piece of large dowel and rubbing to the line. What ever gets the job done. :thumbsup: I have used the last method when tools were short. It is slow but it works. ;)
My friends think I am mad but my psychiatrists thinks I am a real interesting case
glider
Images: 33
Postby Arne » Sat Nov 22, 2008 11:19 am
I've used a razor knife on 1/8". It works, but splinters the wood...
So, I use it where looks don't matter, but where they do, I use a fine tooth jig saw blade, go slow, and back the 1/8th with a piece of pine to keep splintering down.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Re: How to cut openings for doors with rounded corners
Postby Steve_Cox » Sat Nov 22, 2008 12:55 pm
zlamb0002 wrote:I was looking for doors and most of them I have found have rounded corners and I was wondering how to cut openings for them. I am not to good with a jig saw so I was wondering if there was an easier way to do it.
Jig saw quality is an important issue. I have two jigsaws, one is a B&D that cost about $10 when I bought it a few years ago. It has some play in it and the blade goes one speed straight up and down. It will not cut a straight line.
My second jigsaw is a Makita that cost about $130, it cuts in an orbital path and can split a pencil line if I go slowly and don't force the blade. So it seems the practice idea is not bad, but start with a quality tool. I don't use my jigsaw a lot but when I do, if I want good cuts, I pick a good sharp blade designed for the particular cut and the success rate is pretty good. Oh yeah, the cheap B&D jigsaw is the one I loan to the neighbor. :lol:
Steve_Cox
Images: 196
