I think the sink in the drawer that Steve_Cox posted was a cool solution, but would have taken it one step farther, install drain with stopper and use a flexible drain hose to a 5 gal bucket under the sink (could be used for storage when not in use or to a bucket outside to save space inside)
Don C, if you put a cutting board over the spot where the sink was, how much room did you recover....... couldn't you just have placed a cutting board over the sink when not in use....? I know the sink took up space below the counter, but... it was a small sink?
I'm planning on a larger camper (6x12+) with the express purpose of having at least a small galley with sink (I have a double bowl sink, with covers to increase counter space when sink isn't being used and a small oval stainless sink both salvaged from rv) and well as full shower, and already have a rectangular 40 gal fresh water tank, salvaged from old RV, as well as 2 -30 gal plastic jugs, and 50 gal plastic barrel, not sure what I'm going to use, but water is a must.
I've been accumulating parts and pcs for a couple years for converting a van to a mini rv but have decided to do that and camper too, and plan on starting on camper in spring, after finalizing plans and working on the mini rv/van through the winter. Trying to put everything you could want into a small package and still have it functional as well as looking at least halfway decent is always a accomplishment. Between the two, I could live in them... but the wife might not like the idea....
so will have to just do it part time, long weekends, a week or two here and there. (hopefully lots of long weekends and a bunch of week or twos.....)
