satch wrote:Ivar the Red wrote:What if I'm air tool poor?
If you're gonna paint or skin with something else, you can use screws, and when the glue cures, remove them and fill the holes with bondo/putty.
The plan is to paint.
Ivar the Red wrote:satch wrote:Ivar the Red wrote:What if I'm air tool poor?
satch wrote:Ivar the Red wrote:satch wrote:Ivar the Red wrote:What if I'm air tool poor?
Well, then I used screws on mine, then removed and bondo the holes. A bit more sanding, but I think the screws held better on a curve than a brad or staple. Just make sure the glue has cured, I waited 24hrs before removing them.
Ivar the Red wrote:satch wrote:Ivar the Red wrote:satch wrote:Ivar the Red wrote:What if I'm air tool poor?
Then you could prolly use like brass screws with fancy washers, and just leave them in if you wanted to, huh?
Ivar the Red wrote:I keep coming back to this...
Ok, I haven't used any of the new epoxy glues, and with my outdoor shop, and winter temps, am I out of luck until summer? Or will the colder temps just make shorter working times and longer drying times?
GPW wrote:With all the great wood glues out,and careful construction,it seems like epoxy wouldn't be necessary, and since it cures rather than evaporates (wood glue) it adds a lot of WEIGHT...
angib wrote:Yes, but epoxy has superb elongation, meaning it's not at all brittle. Nearly all wood glues fail at fairly low elongation, so are not as flexible as the wood they're bonded to. For an object subject to vibration, like a trailer, brittle is not good.
Andrew
