Door latch question
Postby Nobody » Wed Nov 26, 2008 2:44 pm
Couldn't tell from the pic Mark but if your outer 'flange' doesn't have a good rubber type seal that'll be pulled tightly against the door, I'd put some kind of good sealant there during final installation. Otherwise you can get some water migration during heavy rain/road travel that can stain your inner door paneling (& the outer skin). Don't ask how I know this :oops: .
Harvey -
Nobody
Images: 342
Postby planovet » Wed Nov 26, 2008 4:09 pm
It came with rubber seals (you can see the black layer between the latch and the door). I WAS wondering if that would be enough or if I should add a little extra sealant just in case. But I don't want to make them too hard to get off if I had to some where down the line.
ImageMark (& Cindi)
planovet
The Cat Man
Postby mallymal » Thu Nov 27, 2008 8:07 am
Nice latches... great source, and I'm delighted to see they have a UK link, so a pair of these will defo be going on my shopping list!
Thanks
mallymal
Images: 18
Postby Esteban » Thu Nov 27, 2008 9:35 pm
Very cool looking latches. I like that they have versions with deadbolts. Now that I've seen them I'm noticing them or similar ones in trucks. Would they work in a 1-1/8" thick door? Mine have 1/4" plywood outside, 3/4" wood framing, and 1/8" plywood inside. If needed I could add another 1/8th, or more, inside under the door handle.
Steve - SLO, CA
Esteban
Images: 15
Postby planovet » Thu Nov 27, 2008 11:14 pm
Esteban wrote:Very cool looking latches. I like that they have versions with deadbolts. Now that I've seen them I'm noticing them or similar ones in trucks. Would they work in a 1-1/8" thick door? Mine have 1/4" plywood outside, 3/4" wood framing, and 1/8" plywood inside. If needed I could add another 1/8th, or more, inside under the door handle.
They say they fit 1 1/4 to 1 1/2 thick doors. I guess you could add a 1/8" trim piece.
ImageMark (& Cindi)
planovet
The Cat Man
