Last minute opinions on second layer of roof attachment
Postby EPGregg » Sat Nov 29, 2008 5:00 pm
Last minute opinions on the best way to attach the second layer of 1/8th inch Baltic birch roof.
I’m getting ready to apply the second layer of 1/8th inch Baltic birch to the outside of my tear. Before I jump in I thought I’d ask for any last minute advice. I am leaning toward using polyurethane construction adhesive and possibly using gorilla glue for the edges to make sure there is a good seal. I plan on using straps, 20 lb. bags of sand, clamps, braces and anything else I can think of to make sure I get good contact.
I will eventually seal everything with CPES and Spar varnish, (unless I mess up and end up painting!
Any advice would be appreciated.
Thanks for everything so far!
Gregg
EPGregg
Images: 63
Postby dan galvin » Sat Nov 29, 2008 5:22 pm
gregg polly is a great product and the cost woulf be way way cheeper then
gorilla glue. if you can use ratchett straps 2x4 and sand bags that will work great i just finished mine that way
dan
dan galvin
Images: 43
Postby halfdome, Danny » Sat Nov 29, 2008 6:50 pm
I apply two layers of 1/8" Baltic Birch plywood followed with aluminum. I apply Tightbond ll glue with a plastic Bondo spreader on the whole first layer. I then lay the second corse of full sheets over the first layers joints. I use a narrow crown stapler (1/4" wide) with 1/2" wire staples to hold it down while the glue dries and leave them in place. Some feel one layer will do when covering with aluminum but I like to crawl up on the roof now and then. The two glued layers create a very strong roof shell. If you can staple it all down and Bondo the holes you should be okay. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby 2bits » Sun Nov 30, 2008 7:07 pm
I second the Titebond and staples method. I used a hammer and trim nails but that's only because I don't have any air tools.
Thomas
2bits
2bit Member
Postby wannabefree » Sun Nov 30, 2008 8:45 pm
Where you live makes a difference. Here in AZ, Titebond skins over in about 5 minutes. One trick I use to lengthen working time is to spray down the glue surfaces with water, then spread the glue. For even more working time I'll thin the glue a bit. Heat is not so much the problem as lack of humidity. With 10% relative humidity common, and wood moisture content in the <6% range the wood will just suck that glue dry in no time.
Good luck and let us know how the glue-up goes. I'm about a month away from doing my roof and I'd love to hear what you learn.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Re: Last minute opinions on second layer of roof attachment
Postby Steve_Cox » Sun Nov 30, 2008 9:56 pm
EPGregg wrote:Last minute opinions on the best way to attach the second layer of 1/8th inch Baltic birch roof.
Gregg
I'd roll on epoxy thickened with adhesive filler to go between the layers of plywood, and with the straps, sandbags, and clamps I wouldn't poke any holes in the surface with staples, screws or nails. My tear drop roof is 1/4" red oak plywood and is held on with just epoxy adhesive.
Steve_Cox
Images: 196
Postby EPGregg » Fri Dec 12, 2008 12:05 pm
Thanks for the responses. I'll try to let you know how things turn out.
All of a sudden it's WINTER at 8000 feet!
EPGregg
Images: 63
Postby Roly Nelson » Fri Dec 12, 2008 11:20 pm
6 years ago, I stuck the 2nd layer of 1/8 inch lauan to the first layer using common ordinary panel adhesive, liquid nail type of glue. It has held up well and was easy to work with. Good luck
Roly :thumbsup:
Roly Nelson
L'il Ol' Woody Builder
