After using clear finish marine varnishes like Epifanes for sometime, I started looking for a “better way”. When I say better, I was looking for faster recoat times, easy to brush on and less toxic, all while being as durable and weathering as well as a good oil-based finish.
After testing a number of products, a new oil-modified exterior varnish by Target Coatings called HybriVar stood out to me. It was a breeze to brush on and leveled out great, showing no brush marks. In 62-65 degree conditions it was ready for recoating in 2-3 hours. Lastly it cleans up with water. All this is great but water clean-up clear finishes exposed to the weather don’t have a good track record of holding up.
So I set up and started a durability test November 2007. The test panel is a piece of 9mm marine grade Okoume plywood. It was first sealed on all sides with CPES. The CPES was cured for 5 day. It was then sanded with 220 and 6 coats of HybriVar were applied. The panel was cured for 2 day then positioned horizontally in full sun outside.
** December 2008, one year results:
Over the year the panel has seen a temperate range of 22-100 degrees, it’s seen lots of rain, been cover with snow for about a week, been through many freeze-thaw cycles and baked in the sun. I’m happy to report that so far it is holding up great and shows no signs of degradation. It also shows no notable fading or change in color.
The other finish I mentioned is a colored polyurethane, this is sold as a roll-on finish for pickup beds. It is very durable, holds well against rock chips, is low maintenance and the textured finish covers up minor surface imperfections. The brand I use is Durabak. I’ve been using it over epoxy (normally CPES) sealed wood with no problems for a while now. Since I was doing the clear finish test, I decided to test Durabak over bare plywood.
As with the clear finish, the test panel is a piece of 9mm marine grade Okoume plywood and was started November 2007. The panel was light sanded with 80 grit and two light coats per manufactures instructions were applied. The back and edges of the panel were left bare. After the same 2 day curing period it was also positioned horizontally in full sun outside.
I’m happy to report that so far this test reveals no signs of problems; there is no instance of checking, cracking or delamination. The finish is still shiny and hasn’t faded.
On top one is the Durabak test panel, on bottom is the HybriVar one. The HybriVar is in the middle portion of the panel. On the right side is what happens when an interior clear finish without UV additives is exposed. On the left is a “box store” exterior finish which is still intact, although started to have fogging issues when water pools on it one month into the test.
Based on these results I’m definitely going to start using more HybriVar for my exterior clear finish needs. It also looks like forgoing the CPES sealing of Okoume plywood that will be coated in Durabak will work. For Fir or Pine plywood I’m still thinking I’ll first seal with CPES because of their higher tendency to check. One last thought; if your Teardrop or Tent Top camping trailer is stored inside or under a cover when not in use like I do, this one year full exposure test is probably equal to the exposure your trailer would see in 6-9 years.
