by Arne » Fri Dec 05, 2008 9:48 am
I've used 2 h/f trailers, but have welded them, so they were always straight.
If you want to use bolts and the trailer is bowed, just move the x-member an inch or two and drill new holes to get it straight.
If you have a good floor, you don't need any of the x-members in the middle. You are not carrying a ton of cord wood.
Actually, if you look at the link below , you could do the same thing I did and still use bolts... it just wouldn't look as neat.
