SawTooth XL - Update 6.27.11 - Repairs started
Postby stomperxj » Sun Dec 07, 2008 11:13 pm
Got some more done yesterday and today. I cut the front ribs from 1x2's and glued and screwed them. Then i decided to take it for a tow around my neighborhood to see how it tracks and handled some small bumps...
Thanks for looking
Jess
stomperxj
Postby planovet » Mon Dec 08, 2008 11:06 am
Nice job! :thumbsup: :thumbsup:
(I noticed the WTF on the front panel :lol: )
ImageMark (& Cindi)
planovet
The Cat Man
Postby bobhenry » Mon Dec 08, 2008 12:02 pm
"WTF"
WHITTLE TO FIT
:rofl:
Postby stomperxj » Sun Dec 14, 2008 2:45 am
planovet wrote:Nice job! :thumbsup: :thumbsup:
Ha ha yeah my router decided to have a tizzy fit right there... :)
So I got some stuff done the last few days. The second door is cut out, the front window is cut out, insulation is in... About the insulation; I didnt know this but apparently 1/2" rigid pink foam insulation is 9/16" thick :thumbdown: I glued all the foam in and then decided to shave it all down with a 40 grit disc on my D/A sander. It worked quite well but now i have pink foam dust on EVERYTHING... it vacuums up ok but it got everywhere still. On to the pics:
I also built a mini door mockup so i could finalize all my door variables...
That's it for now... more soon I hope. It snowed here today so I think winter has finally begun....
stomperxj
Postby mikeschn » Sun Dec 14, 2008 6:10 am
You might also consider using a spray adhesive on your pink EPS. Because the adhesive disolves the foam, it might take it down to the right thickness. If not, you'd still have less to sand! :o
I hate it when my router doesn't behave.
Postby Miriam C. » Sun Dec 14, 2008 9:33 am
:applause: :applause: :thumbsup: Goodness you are doing a great job. The Sawtooth looks fantastc and it isn't even done. :thumbsup:
Postby stomperxj » Sun Dec 14, 2008 11:52 pm
mikeschn wrote:You might also consider using a spray adhesive on your pink EPS. Because the adhesive disolves the foam, it might take it down to the right thickness. If not, you'd still have less to sand! :o
Thanks Mike 8) It didnt take too long to sand it all. It was just a mess :)
Miriam C. wrote:Goodness you are doing a great job. The Sawtooth looks fantastc and it isn't even done.
Thanks Miriam ;)
I got some more done today. The weatherstrip rings are cut out and i routed a door too so I could check fitment...
stomperxj
Postby grant whipp » Mon Dec 15, 2008 1:28 am
Man, this shot looks familiar! I can't tell you the number of times I've been in nearly this same position! (Well, actually,I can, but ... ;) ...)
We oughta make up a shirt with this image that says:
Been There ... Done That ... Here's The Shirt To Proove It!
(it's a teardrop thing ... you wouldn't understand ...)
Damn nice work, BTW! Can hardly wait to see this one finished!
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
Postby stomperxj » Tue Dec 16, 2008 2:28 am
grant whipp wrote:Damn nice work, BTW! Can hardly wait to see this one finished!
Thanks Grant :thumbsup:
All the hinges I found that I liked were way too expensive (in the $30 each range) so I ran over to dads shop and made up some hinge plates tonight. I'm making my own out of 1/8" steel plate and some weld on hinges from McMaster Carr (item #1071A22)
More later :)
stomperxj
Postby Wolffarmer » Tue Dec 16, 2008 7:30 am
I see this cold weather is not keeping you down.
Looking better all the time.
Thanks for part #. I know that on my next one ( whoops, did i say that ?) I will have to build my own hinges. Those little beauties will make it much easier and probably work a whole lot better.
Wolffarmer
Images: 309
Postby Snowdrift » Thu Dec 18, 2008 1:33 am
[quote="stomperxj"][quote="planovet"]Nice job! :thumbsup: :thumbsup:
[img]http://img.photobucket.com/albums/v236/stomperxj/SawTooth%20XL/sm-00330.jpg[/img]
Hey stomperxj, I have been following your build your doing great, very inspirational. you probably already know how to fix this, But I have used Bondo to fix wood before and seems to hold up great. Keep up the good work. :applause:
Snowdrift
Postby 05liberty » Thu Dec 18, 2008 8:36 am
I wish all you guys would stop these cool builds... now im thinking of redoing mine ... and its not done yet .... :lol: Really this is an awsome build ! keep the photos coming ! getting lots of insperaiton & ideas from it :thumbsup: ... now just have to wait for the snow to melt ( some where around april :cry: )
Dave
05liberty
Images: 63
Postby Endo » Mon Dec 29, 2008 5:26 pm
Any updates?
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby stomperxj » Mon Dec 29, 2008 8:38 pm
Hey Endo - i saw your comment on my youtube vid... Nothing to speak of lately. It has been super cold and snowy for the last couple weeks and the only nice days like today have been taken up with Jeep stuff. I tore apart my front axle chasing a bad noise a couple weeks ago and everything checked out there so today i tore out the transfer case and i'm in the process of getting that back together... Looks like it should be around 40* the rest of the week so I might get out there to do something...
Thanks for checkin in 8)
stomperxj
Postby aggie79 » Tue Dec 30, 2008 9:21 am
You were rockin and rolling pretty good on your build, and got me hooked on this thread. Any updates?
Return to Member Designs
